Results 1 to 9 of 9
Thread: storing bucket of trichlor tabs and bucket of cal-hypo
    May 2011
    Montgomery, TX
    176
    i have this big grey plastic container i store my 50 lb bucket of trichlor tabs in. i just bought a 50 lb bucket of 73% cal-hypo granules. if they are in their own seperate buckets is it going to be alright to store them both in the same large plastic container outside? i know about not mixing them, just concerned about the fumes from each mixing? thanks
    Feb 2008
    Denton, TX
    5,061
    Re: storing bucket of trichlor tabs and bucket of cal-hypo
    Both of the containers are probably vented and therefore, I would probably consider storing them in separate locations.
    Mar 2007
    Coastalish 'down easter'
    4,160
    My take is that as long as they can't come in physical contact with each other they off gas the same thing and could be stored in the same bin. However, it's always better to be safe...
    Luv& Luk
    -Ted
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    What happens if calhypo and trichlor mix?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Mar 2007
    4,160
    There is a fair chance of fire or explosion when 2 forms of chlorine get mixed together. (I was looking for a mushroom cloud emoticon ) As long as we're talking about this, letting acid touch chlorine is even worse!
    Luv& Luk
    -Ted
    May 2011
    Montgomery, TX
    176
    Quote Originally Posted by waste
    this is what i was thinking. they are in their own bucket with lid. i will put them in the same bin and will update this thread if it explodes.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Really! That is something every pool owner shoud know. Don't mix Clorox and muratic?!
    Jandy 2 speed pump
    Quote Originally Posted by brg88tx
    I have a bucket of trichlor tabs alongside a bucket of cal-hypo in an outside storage unit. Suncore (or something like that) maybe 3' tall and 6' wide. Each stay dry inside the bucket even when rain gets into the storage unit. I do, however, store the muriatic acid elsewhere outside. And the bleach is in the house or garage, depending on temperature.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by texasdad
    Mixing Cal-Hypo and Trichlor is explosive! (click on that word to see what I mean). Storing them next to each other in sealed containers is only a problem if the containers were to leak/burst and the chemicals then mix.
    The result is production of chlorine gas.
