Thread: First time opening pool
    Awesome site! I put an inground pool in last August. I hired the builders to close it but I would like to try opening it myself. Here are the details of my pool:
    1) 18 x 40 rectangle with auto cover
    2) 22,800 gallons
    3) chlorine pool
    I already put 3 lbs of shock in it because of the mild winter and warm srping we have had. I called the builders and they said it wouldn't be a bad idea. Here are the notes I made to open it. This was from watching them close it and askiing questions.
    1) Replace all drain plugs
    a) main pump - 2
    b) second pump - 1
    c) filter - 1 drain, t sight glass, 1 gauge
    d) heat exchange drain
    2) Drain anitfreeze from each skimmer line
    a) open one line and turn pump to waste utnil anitfreeze comes out
    b) close first line and do the same for second
    3) Remove gizmos and replace plugs
    4) remove all line plugs and replace with nozzle head
    5) start filter
    Am I missing anything?
    Any suggestions on initial chemicals? Should i just take a sample and go from there? The water looks pretty good.
    Thanks for any help!
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    Sep 2010
    Noblesville, IN
    104
    Re: First time opening pool
    Welcome. Let me be the first to recommend a test kit from the folks that run this site. Lots of free info here so give em a little business. I'm sure smarter folks than me will chime in and help you out.
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    which kit is theirs?
    Jeremiah Hough
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Re: Re: First time opening pool
    Quote Originally Posted by miahhough
    http://tftestkits.net
    The TF100 comes highly recommended. I ordered one myself. It's a nice kit, and the shipping is fast. Also got the Speedstir.
    Sent From My Inspire 4G Using Tapatalk
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    You can skip 2a/b. Hopefully your PB used RV antifreeze....that stuff is non-toxic and can go straight into your pool water. Take the winterizing plugs out, put the return eyeballs back in, and crank er up.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    The only thing you can be sure you will need is chlorine. Everything else depends on where your levels are. Run the pump for at least an hour to get the water well mixed, then test everything and see what levels you need to adjust.
