Thread: Borax and SWG
    Borax and SWG
    Are you using borax in the pool also to keep the chlorine level low or not bothering? One pool guy strongly recommended the Protein Supreme route and then possibly switching to a SWG after, stating that you should always use it in a SWG pool, and another said not to bother, Opinions??
    Feb 2012
    North Texas
    19
    Re: Borax and SWG
    I suggest you read this article on why borates are added to the pool. It may answer all of your questions.
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    Oct 2011
    New Caney, Texas
    414
    Re: Borax and SWG
    I use borax in mine but not the pool store stuff. I shop at WalMart
    Have a read here:
    http://www.troublefreepool.com/so-yo...how-t4921.html
    [Edit] gcalahan beat me.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Borax and SWG
    Ditto here, I use the cheap stuff. I don't think using it to keep algae in check is a good idea; chlorine is much more foolproof. The pH buffering effects are real and important if you have a SWG.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borax and SWG
    First time I did the borax and acid. When I had to add I did boric acid. It cost a little more but was easier overall
