Thread: Valve / Actuator not closing all the way
    dissfigured's Avatar
    Oct 2011
    Denton, TX
    51
    I believe I have a valve that is not closing completely.
    When I switch from spillover to pool I notice over about 2-3 hours time, the spa drains to where the water level matches the pool water level.
    My spa is about 2 feet above the pool. so it drains the spa about half way.
    It seems is I go out there and pull the valve, it has another quarter inch of turn remaining in it.
    If I do that each time, the spa remains full. It is like the actuator is stopping and the valve remains open just enough to let water seep back to the pool.
    What should I do?
    In-ground, SWG, 20,000 Gallons, Attached spa w/ Spillover, Hayward system, Cartridge Filter.
    Dallas TX
    38,242
    Re: Valve / Actuator not closing all the way
    I am pretty sure most actuators have stops that are adjustable. You may just need to adjust them so that you get a full close. Which actuators do you have?
    Oct 2011
    Denton, TX
    51
    I will find out when I get home this evening. It is a hayward system. That is all I know.
    I have actuators on 2 of the valves. 1 for the suction side, and one for the return side.
    Dallas TX
    Oct 2011
    Denton, TX
    51
    I don't know. Do these pictures tell you anything?
    Dallas TX
    22,542
    Is that pic after you "manually" closed it?
    If it is then you can take the top off the "box" part of the actuator and the limits are in there. You may hove one that is stopping the valve before it's 100% closed.
