Results 1 to 8 of 8
Thread: newbie with a (possible) stupid question.
    im about to drain and clean my in ground pool (approx 25x13) and was wondering if i could coat the inside with the gray garage floor epoxy stuff. would it hold to the chemicals? just an idea for something different. oh, and i believe it's gunite based (house was built in the mid to late 70's i believe, with the pool).
    Still holding on to the grass so I wont fall off the planet!!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: newbie with a (possible) stupid question.
    Welcome to TFP!
    Typically epoxy paint coatings last for a couple years tops. Why are you draining the pool?
    30,414
    Welcome to the forum. The chemistry in your pool water won't be nearly as troublesome as what that paint would run into on your garage floor. That said, I wouldn't use it simply because there may be some unintended consequences no one is aware of.
    As MITS says above, even Pool paint is probably good for only a couple of years.....depending almost entirely on surface prep before you paint.
    good call. thanks guys. and im draining it cause its green with algea from serious neglect. time to bring it up to par. i would throw a pic up but i dont want to scare people.
    Oct 2009
    3,899
    No need to drain for algae...and I'm not scared of your pics! Here's the advice you need:
    pool-school/shocking_your_pool
    The rest of Pool School (button in the upper right corner) is important to read! You won't regret it.
    30,414
    MITS is right, E_ROC. We can help clear virtually any pool for a lot less money and time than draining. Keep reading about green pools on the forum.
    will do guys. thank you.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Not only can you clear the water back to it's original, showroom-fresh sparkly glory, but fully draining a pool can have catastrophic consequences if the water table is not completely beneath the lowest level of the pool shell. A pool is just a boat in the ground. If you are not absolutely sure, do not drain it completely.
