Thread: How soon can I add chlorine after adding liquid stabilizer?
    Apr 2011
    Palm Harbor, Florida
    90
    Multiple readings of CYA = 0 was confirmed (testing with old TFTKit chemicals, plus new chemicals I received today in mail, and at pool store). No wonder I had a hard time maintaing any chlorine levels
    Poured in liquid stabilizer just now, how soon afterwards can I add liquid chlorine where I know it would hold better than before with zero CYA levels?
    Thanks in advance.
    Florida-style enclosure (lanai) housing 18,000-gallon outdoor in-ground salt pool/spa, PeebleTec finish. Spa water waterfalls into pool. Hayward model 17502 cartridge filter system, Hayward SP3400VSP EcoStar Variable-Speed Pool Pump. One skimmer, Baracuda Zodiac MX-8 cleaner. Palm Harbor, Florida
    Oct 2011
    New Caney, Texas
    414
    Re: How soon can I add chlorine after adding liquid stabiliz
    I used the liquid stabilizer on mine and I added bleach an hour later.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Apr 2011
    90
    Quote Originally Posted by George N
    Okay - so a hour of pool circulating the new liquid stabilizer (CYA) should be reasonable before adding new chlorine? That's pretty quick - Thanks!
    30,426
    Yeah, the liquid CYA shows up right away in your pool.
    For planning purposes, you can also ASSUME the CYA is in your pool (and dose chlorine accordingly) if you use powdered CYA....even though it won't show up as a test result often for as much as a week.
