Results 1 to 10 of 10
Thread: split return
    split return
    Due to an underground leak in pipe, I am forced to use just l return. Fortunately it is in the middle of the pool wall (inground vinyl). Does any one make a split return--one the screws into the return but has 2 (or even 3) forks that move the water in more than one direction. I read the reviews on a rotating return, but it had bad reviews. Have I made myself clear. It would loo like a Y (or W) with the screw-in part straight behind it.
    26,000 gallon in ground
    in floor caretaker system
    sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: split return
    Welcome to tfp sbledsoe
    Generally you want the pool to circulate or move the water in one direction so that the whole surface moves towards the skimmer/skimmers. Where are your skimmer/skimmers in relation to the return? A pic would be great!
    Re: split return
    The skimmer is almost directly opposite the return. (It is a Roman style shaped pool)
    sand filter
    22,544
    Re: split return
    The best you could do is probably make one yourself. I'd first try to aim the eyeball toward one side and see if I could get the pool to circulate around somewhat. You may find that, that's all it takes. If that doesn't do it then a specially designed return might be your only hope.
    Re: split return
    I have drawn out what I need but I can't make it. Do I go to a plumber, pooler, or who to help make it?
    sand filter
    22,544
    Re: split return
    Head on down to your local hardware or plumbing store (not big box) and show the plumbing guy what you want and maybe they can help. If not they may know someone. Another alternative is to take it to your local pool store and see what they say.
    Re: split return
    Thank you
    sand filter
    Re: split return
    I found what I needed. A 3 way splitter, a connector with male grooves, and 3 eyeballs that fit into the splitter perfectly. All these things fit together very well so I have water moving 3 ways--better than it ever has. It sticks out about 3 inches, so when there are swimmers, I can just unscrew it. Then put it back for circulation. Thanks for your responses. (By the way, it all cost lest than 10 dollars)
    sand filter
    38,267
    Re: split return
    I am sure people would love to see pictures
    Re: split return
    When the water clears more, I'll post some. I would jinx it to take it apart now.
    sand filter
