Thread: Salt
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Salt
    I have been trying to find where I can post a question about how to add salt to an SWG pool as I am low on salt.
    1- Is there a preferred method of adding salt? (I looked all over the site for the topic.
    2- I could not find where I can post the new topic, so I came to this place on the site. Do you make it hard for us to do this on purpose? No offense meant, just a question
    Could not find any instructions in the calculator or in the Chemisry School
    Should I just dump it in? Should pump be running? Should SWG chlorinator be off? ETC ETc
    Cush Dobbs
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    Oct 2011
    New Caney, Texas
    414
    Re: Salt
    Add salt, brush it around, run pump at least 24 hours, turn on SWCG.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Salt
    George has got you covered! I just walk around my pool as I dump it to attempt to evenly spread it out. My pump is running.
    Quote Originally Posted by cood60
    Salt Water Chlorine Generators (SWG)
    Re: Salt
    Recommended Pool Chemicals in Pool School is a good place to look for answers to this kind of question.
    Salt can be just dumped in, after which you want to run the pump for 24 hours and keep the SWG turned off for 24 hours.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Salt
    You don't have to purchase "pool salt", water softener salt works fine, it's a little courser and will need a little more time to dissolve depending on water temperature. When I first added salt on my install it took 45 minutes for about 400 lbs to dissolve. Added salt, brushed sides and mixed it in. The salt looked like diamonds on the bottom of the pool for a while, looked pretty cool.
    38,524
    Re: Salt
    Look for "solar salt" as that does not have any additives and is cheaper than the pool salt but has the same purity.
