Thread: Sealing a new pool deck?
    Mar 2012
    Lebanon,Tn
    47
    I have a new concret deck with travisten copeing . I would like to seal this before we put the water in. Any ideals? Everything I have looked at said not for pool decks.
    21x42 olympic sports pool
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    TR100 Pentair sand filter
    Letro ledgen II pool cleaner
    Vinyl liner
    TF Test Kit's TF100
    Feb 2012
    Phoenix, AZ
    728
    Re: Sealing a new pool deck?
    Hey fishunt, welcome to TFP!
    You will want to use a sealant specifically made for pool decks. I am not familiar enough with the brands to have a best recommendation, but I did some research and found a few options. I will send you more info via PM.
    Do you mean travertine coping?
    Is the concrete plain white concrete, or something different, like stamped concrete?
    Support the site
    Mar 2012
    Lebanon,Tn
    47
    Plane white, and yes travertine coping yes .
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    Vinyl liner
    TF Test Kit's TF100
    30,431
    I am certainly not an authoritative source but I have seen plain concrete sealed with less than satisfactory results. It took the seal very unevenly and was blotchy looking. I personally would suggest not sealing it.
    The travertine might do well but I believe it also functions just fine unsealed.
    I would leave the plain white concrete unsealed. I would have some concern about the travertine around a salt pool. I would suggest a penetrating sealer made for this purpose, such as in the links below.
    http://www2.dupont.com/Stone_Tech_Profe ... il2010.pdf
    http://www.deckoseal.com/01/24/deck-o-s ... nt-sealer/
    http://www2.dupont.com/Stone_Tech_Profe ... index.html
    http://www2.dupont.com/Stone_Tech_Profe ... ealer.html
    Support the site
