Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Cartridge Filter-Outlet hose screen fills w/ debris daily
    Have a Haywood 4 cartridge system. There is an outlet on side of pool below water surface to the polaris pool cleaner. This hose has a fine screen to trap debris so it does not harm the polaris.
    The debris getting past the cartridge filters is so bad, that I must clean the screen daily, else the water pressure drops off enough that the polaris does not run.
    I clean the cartridges faithfully and examine them for any tears or holes... there are none. The system is plumbed correctly.
    Is there anything that can be done to prevent so much debris from getting around the cartridge filters?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Cartridge Filter-Outlet hose screen fills w/ debris dail
    Is there a booster pump for the cleaner? Does the cleaner line bypass the filter? It is difficult to envision that debris big enough to be trapped in a screen can get through a working cartridge filter.
    Could you snap and post a couple of photos of your equipment so we can see the setup?
    Dec 2010
    San Diego, CA
    1,137
    Are the cartridges seated fully and are you sure they are the right size? Have you replaced the cartirdges recently? Someone recently posted a similar problem of debris getting past the filter and it turned out the aftermarket cartridges they bought didn't seal properly properly even though they seemed to fit correctly.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    There is not a booster pump for the Polaris and the filters are the original OEM cartridges (installed system 24 months ago) from Haywood and are correct for this filter system.
    In the two photos - I'd cleaned the screen earlier today. It is filled w/ debris again, as seen in the photo.
    Since the debris has accumulated so quickly, I now believe that I've been looking at the filters in the wrong way when cleaning. Could it be that there is a separation of the filter material from the housing? I.E., either at the top or bottom, the filter material is just "laying up against" the top or bottom disc?
    Is this a possibility? Or is there something else to look at?
    Dec 2010
    San Diego, CA
    1,137
    I would definitely try a new set of filter cartridges.
    30,431
    What is that "debris"? Are those seeds? There is absolutely no way something that large could ever bypass ANY type of filter so something is clearly incorrect.
    Yes, those are seeds and other. Ever since the install the particles in the debris has been about this size. Only now when there is so much wind with all the new growth scattering seeds, foliage bits, etc., it really gets bad.
    However, with our previous DE filter we had similar problems, just not nearly this bad. Definitely something with the cartridges. I was thinking that the stuff was getting around the filter media... perhaps something to do with the seal 'clamping' the cartridges in place. Don't believe that's the issue now.
    Thanks for the help and getting me to think this from different direction. Will post next week about what I found.
    Apr 2010
    Buckeye, AZ 85326
    619
    Sorry for your trouble. As others have stated and you are concluding something isnt right with the filter sytem. But i though I would mention the use of a skimmer sock or filter saver for added protection and to also make sure your skimmer and pump baskets are working properly.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    22,553
    I'd be interested in what you found. It had to be bypassing the elements either through a tear or an intentional bypass for anything that size to get by.
    May 2009
    Dallas, TX
    785
    I almost responded to this post yesterday with the comment: Seems like the debris in the picture was too large even to get past the pump's strainer basket.
    Fast forward to this morning: As I was reeling in the polaris for routine bag empty/cleaning, I looked down and lo and behold I noticed debris in that same screen as OP! Not only that, but the debris was much too large to get past filter media.
    So just to recap, is the consensus here that there is only one way that the debris could have gotten there? Namely, a compromised filter? Is the purpose of the screen simply a last line defense in the case of a compromised filter, or is there some other "normal" mechanism involved when the screen catches stuff?
    I know, I could answer my own question by disassembling the filter to see for myself, but indications are that the filter is operating normally. Meaning, I let my pool go green before starting normal maintenance this year. Not only that, but I had also let significant debris accumulate in the pool. My point is that my pool is now clear & clean, and it happened precisely as I would have predicted. Took about 3 days.
    Seems like filter is working, but how else to explain the presence of large debris in the polaris screen?
    Baffling, simply baffling...(where's Hamish when you need him?)
    Note: edited to avoid confusion in terminology
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    As Ohm_Boy asked, I would point out that my pressure side cleaner line comes off of the pump output before the filter. Does yours, beez?
    35k inground Plaster w/ attached spa, 2hp Pentair single speed pump, EasyTouch with Intellichlor, 48 Sqft DE filter, BBB managed
    Need a heater!
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by Locksmythe
    Well sir... Didn't see that pertinent point in POST #2 but that would explain a lot! I'm afraid I'm not fit for Lochdubh after all.
    That would be my ADD working for me! I would point you to my avatar... Carry on.
    May 2009
    Dallas, TX
    785
    Oh, and thanks for setting me straight!
    22,553
    Enough said! Should have read more carefully!
    Well in the pictures of the OP's pad it does not look like the line splits off before filter, so this point only applied to Beez.
    Need a heater!
    May 2009
    Dallas, TX
    785
    There's no doubt about that! And a pre-filter plumbing setup would certainly be an easy answer to the question...
    But as concerns my own plumbing setup, the polaris pump is definitely post filter. And as far as I understand it I would question the wisdom of plumbing it any other way...
    So the mystery continues...
    baffling, simply baffling...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Beez, if your booster ever runs without the main pump on, it will suck unfiltered water in through the returns; that could cause what you're seeing.
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by Melt In The Sun
    AHA! I think you may be on to something here...check me out on this...
    My booster cannot run without main pump on, because they are wired together. However, I *did* have a suction leak earlier that caused partial starving of the main pump. In that situation, is it possible that the booster pump actually sucked water in from the returns?
    May 2009
    Dallas, TX
    785
    Another possibility I considered: Could the multiport valve be considered as suspect? The reason I ask is that I thought of one situation where the filter would definitely be bypassed. That of the recirculate position on the multiport.
    Now I never used recirculate, but I did use waste. So the question for those who understand the esoteric principles of plumbing is: Could the multiport be the point of incursion taken advantage of by the wayward debris that made it to the screen in polaris line?
    I'm just brushing up on my intelligence skills...still bucking for that PC position in Lochdubh...
  20. Back To Top    #20
    38,449
    Quote Originally Posted by Beez
    I have definitely put my multiport on filter after a backwash and end up loosing a lot of my new DE out the backwash when the multiport did not seat completely.
    So I suppose there could be a chance that water could bypass the filter due to a screwy spider gasket or the valve not seating ... although I am not too familiar with the inner passages of the multivalve which may not make this possible.
