Results 1 to 9 of 9
Thread: Live in Michigan, peeked under cover, GREEN, what to do?
    Oct 2010
    michigan
    284
    I live in michigan, won't open the pool for another 2 months, I peeked under the cover and it was GREEN GREEN, lol Should i do anything to it now? or wait 2 months? lol I would assume it would even get worse in 2 months. When they closed the pool i don't think they shocked it well enough.
    so what should i do?
    15,000 inground fiberglass pool with spa.
    Curious question, Why is the water on top of the spa cover crystal clear, while the water inside the pool is GREEN GREEN.
    help much appreciated, thanks
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    22,543
    Re: Live in Michigan, peeked under cover, GREEN, what to do
    If it's winterized (and I assume it is) then I'd wait till opening to deal with it. In order to do anything about it now you'd have to de-winterize it and that would create a whole new set of problems to deal with. In the mean time I suggest you read and become best friends with the pool school articles on how to defeat algae.
    30,408
    Yeah, you'll need to wait 'til you open or you'll end up doing it twice.
    You will be able to shock your pool into submission with a little diligence and a lot of chlorine..
    Can't answer your question about why the spa is not green. Algae, in it's thousands of forms, likes certain conditions and dislikes others.
    Oct 2010
    michigan
    284
    problem is we are having way above average weather, 60+ degrees all week and gonna touch 70 degrees today.
    if i do nothing isn't it gonna become a thick green goo if i do nothing for 2 months?
    problem is i have a mesh cover and it allows some sunlight to get thru.
    Well will have to listen to you guys and leave it alone for 2 month till i open it. (pool is 3 years old)
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Maybe cut the open time in 1/2. With these warm temps we're having I'm debating about opening in early to mid April here in Ohio. You'll still have to fight a green pool, but you'll run into a chance we keep warm temps up and have a longer swim season. Leaving it will allow green stuff to keep growing, but it won't take much more to shock it when you do open. We'll help you out. If you really wana do something, start stocking up on bleach.
    Feb 2008
    Denton, TX
    5,061
    As dramatic as a green pool appears, it is easily shocked into submission. Wait until it is time to open. Doing so will not make it harder to clear. Trust us...we have been down this road before.
    Mar 2012
    hamilton ontario
    10
    hey guys first post here for me been a long time reader first time poster
    op- im in southern ontario and opened yesterday lol
    maybe consider opening earlier???
    13x20 onground pool
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by smooth2222
    It may be a difference in nutrient levels since the top of the spa cover may just have rain water. Or it could be the difference in sunlight exposure -- some algae likes light while some species do not.
    Aug 2011
    Western NY
    6
    In sunny Buffalo NY here! Same thing peeked under the cover and green! We usually open May 1st we will try to open earlier if we can this year because of the abnormally high temps however... It is Buffalo we're probably due for another snowfall LOL!
