Results 1 to 7 of 7
Thread: Suggestions for skimmer locations?
    Hi, first post and need to say thank you for all the helpful info I've researched here the last two years. I usually find an answer to my questions just by searching. But now I'm need of routing ideas.
    Thanks to some great posts here, I'm ready to make some plumbing upgrades before spring rains start. Most of my pool specs are in my sig. I want to keep current out to pump as a vac line, add skimmer, maybe an extra return with a fountain option and hard plumb lines with pvc. The one return doesn't seem like it really circulates enough. Current out and return is in the middle of a long side about 8ft apart. So I'm looking for best opinions on where to locate and space stuff out for best water flow inside and out. I might play with making diy solar panel on short end of the pool that faces south.
    2012- making plans...
    2011- bbb
    2010- Hayward Sand Filter & 1.5HP PowerFlo pump
    2009- Intex 16'x32'x52" Ultra Frame, Intex SWG, 14k+ gal.
    22,553
    Re: Suggestions for skimmer locations?
    The best place for a skimmer is downwind of the prevailing winds in your location. We hear a lot of stories about the skimmer not being downwind of the prevailing and debris collecting on that side and not making it to the skimmer. I would place one there and if there is to be a second one, I'd place it on the opposite wall.
    30,432
    Double ditto what Bama just said. I would also make a second skimmer a near certainty.
    I would love 2 skimmers but I can only add 1 right now. I think if I do something like this, it should work.
    2011- bbb
    Oct 2011
    New Caney, Texas
    414
    Forgive me if I'm wrong but it appears that the pool is not level. If you put one there do you plan to level the pool?
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    The pool itself is level, my camera angle is not so it just looks really off until it fills all the way up. A couple of block supports are a bout 1/2" off. We had to dig out and add them in after a flash flood last summer. Thank god for the deck or it would have caved.
    2011- bbb
    22,553
    That looks like a decent plan. You can aim the eyeball upwind and have it circulate the pool clockwise and it should take the debris right past the skimmer where it'll get sucked in. Mark the water level carefully before lowering it to install the skimmer. You'll want the skimmer about 2/3rd's submerged.
