Please forgive my extrememly limited knowledge but any help would be appraciated.
We have three pumps, one for a waterfull, one for a slide, and the pool/filter pump. We just refilled the pool after redoing our stonescape surface. There is an air release valve on the filter which we used to prime the filter pump, which is currently working fine. We winterized the other two, in the fall and now need to prime them as well.
Do we use the same air release valve that is on the filter? I wouldn't think so because that would cause problems with that pump.
There appear to be some valves on the waterfall and slide pumps but there is no pressure gauge. Are those the air release values? Any help would be much appreciated.
Thanks.
Thanks.
