Re: Can I run Cartridge Filter with the 4 cartridges removed
Jblauert
Thank you! I am back again.
The floor system is Paramount 2000 Two modules, a 6 port and 3 port. I am not aware of a filter of any type
in that system. The modules (6 and 3) have water driven "pistons"(?) that either work or don't work--no inbetween.
If an item, perhaps a pine needle, gets stuck in the 'piston" while it is open, a malfunction occurs. I will remove and
check the controllers for obstructions. There is such a great drop in pressure--from 35 to 22--when the
"Aqua Pure" by-pass is opened. I am not sure where to check for a blockage in the heater. It is a Hayward "large" heater.
I can do better than that, sorry.
The missing o-rings on the cleaner/spa valve...is that a big problem?
I replaced the cartridges in the heater earlier. There seems to be too much "water noise". I may just not have
listened for "noise" before, but I hear almost "gurlgling" while the system is running. Especially in the plumbing
into/out of the heater--aqua pure.
I will make sure I have answered all of your questions. I am waiting for the o-rings and I need to buy a replacement
spring valve "plunger"(?) for the "White pipe".
Jblauert
