Thread: Need help identifying pump motor for replacement
    Oct 2009
    Cumming, GA
    13
    i'm replacing the motor for my Jandy MHP 2.0 pump used for my spa jets. can someone help me identify which motor I need. I've contacted several pool companies online and there is a difference of opinion. some say i need a 2HP Up-Rated and some say i need a 2HP Full Rated. i'm just replacing the motor so i need to make sure everything matches up.
    i'm attaching a picture of the label if anyone can help.
    thanks.
    Feb 2012
    Phoenix, AZ
    728
    Re: Need help identifying pump motor for replacement
    Hey Clay, here is the information about your motor!
    AO Smith Motor sku# B855
    Motor Shaft Seal sku# 634016
    Pump Body O-Ring sku# 635028
    You can go with either a Full Rated or the Up-Rated B855.
    You currently have the Up-Rated so the B855 should be a direct replacement.
    22,542
    That's a 1½ hp full rated or a 2 hp uprated motor. A B849 or a B855 motor will work, but you'd be better off going with a 2-speed. That would be a B983 or a B985 or an E+plus B2983.
    Blake was faster but I'm posting anyway!
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Oct 2009
    Cumming, GA
    13
    thanks for the info. that will save me a little bit of money.
    if it's only for the spa jets, what would be the benefit of the 2 speed?
    22,542
    If it's only for the spa jets then I'd stick with the single speed.
