Thread: Swimming season filtering process
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Since I am still a bit green to pools, what is the proper way to run my filter during the swimming season? I left my pool open this winter and have been doing great keeping the water clear and balanced. Wondering what sort of changes I will encounter when the grankids start enjoying it.
    Thinking about some sort of heat scource and would appreciate any advice. Would love to Geo-Thermal, but wow it seems expensive!
    Thanks
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Swimming season filtering process
    Pump run time is one of those things that is very much and individual thing. With a 2-speed pump and an SWCG, long run times on low speed would probably be a good start point, but if you have a lot of surface debris you might need some high speed runs too.
    Feb 2012
    Phoenix, AZ
    728
    This is the best place to start pool-school/pump_run_time
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    This is my first summer with the pool. Water balance has been great, thanks to all yous
    We have had a couple of weeks with 90s to 100s
    Pool water is not quite as clear and sparkly, is this normal for extreme heat?
    Pump runs on high for 3-1/2 hrs in the morning, 2-1/2 in the evening, runs on low speed the rest of the time
    last test results were:
    PH-7.7
    TA- 70
    CC-2-3
    CYA- Just had to raise it from 30 to 60 (Chlorine was still doing ok but I raised it anyway per TFP School
