Thread: Auqarite not generating, Power light is on
    Auqarite installed with new pool 2004. Has been virtually trouble free. Replaced cell last year. I have been adding chlorine to keep pool clean. Power on light is on, but no other lights.
    Diagnostic display: Temp 80, Cell Volt 30.8, Cell Current 0, Desired output 50%. Instant Salinity 0, Product AL-5, SW r 1.33
    Water tested today. Salt was low, but added 100 lbs to bring to desired level.
    FC 4 ppm
    PH 7.6
    TA 120
    CH 250
    CYA 60
    Jim4506
    16 X 30 10K gallons IG Gunite
    Cartridge Filter
    1 HP pump
    Auqarite SWC
    Solar Heat
    Feb 2008
    Denton, TX
    5,061
    Re: Auqarite not generating, Power light is on
    Are you certain that it isn't generating? Hold an empty hose up to a return and fill a bucket up with the water. Then test it for the presence of chlorine.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Is it a Aquarite cell, or aftermarket?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Quote Originally Posted by 257WbyMag
    Before I starting adding chlorine the pool was turning green and tested no chlorine.
    Jim4506
    Cartridge Filter
    1 HP pump
    Auqarite SWC
    Solar Heat
    Quote Originally Posted by maxepr1
    It is an auqarite cell. Worked Ok for several months.
    Jim4506
    Cartridge Filter
    1 HP pump
    Auqarite SWC
    Solar Heat
