Results 1 to 8 of 8
Thread: Thermal Regulator problems
    This is the second time in the past year I have needed to replace the thermal regulator (thermostat) in my Sta Rite MaxETherm.
    This is used on a ~1200 gal. saltwater in ground spa.
    This one is 6 months old. They have rarely lasted past 1 year.
    Here's the one I just pulled. You can see the crack in the center shaft and it is completely frozen.
    [attachment=0:mik7pnhz]ThermReg1.JPG[/attachment:mik7pnhz]
    I thought I kept very close eye on my water chemistries but clearly there is something not right. Is there a specific thing like ph or hardness that might be accelerating this problem? Can anyone offer any advice on how to get these things to last longer or can I just leave it out. It's become a bit of a PITA.
    The heater works well without it right now- no error codes!!!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Thermal Regulator problems
    Welcome to TFP!!
    It certainly looks like something's wrong.
    The color doesn't look right, so I suspect a chemistry issue.
    Can you post some test #s and tell us how you came by them?
    Luv& Luk
    -Ted
    Thank you waste!
    I am glad I came across this forum. Lots of very knowledgeable people and good info to be found.
    The pool is exposed aggregate.
    I find I need to add acid often due to the pH continually drifting upward.
    Here is a snapshot from today: (I dropped this off at the local pool store for a complete analysis, it's usually pretty close to what I get)
    TC: 5 ppm
    FC: 5 ppm
    pH: 7.8
    AD: 1
    TA: 85 ppm
    CH: 215 ppm
    Stab: 30 ppm
    Salinity: 3200 ppm
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Odd.
    To me, that "thermal regulator" sure does look a lot like an automobile cooling system thermostat. On my truck, one of those has lasted for pretty near to 20 years in the ralph-awfulest mess of liquids similar to water with a wide range of antifreeze dilution and some varying consistency lumps of rust and stopleak, over temperatures from freezing to around 230*F with absolutely no consideration for ph or calcium or algae, and while it may fail tomorrow, it hasn't batted an eye yet. I cannot imagine what might could cause that kind of split.
    22,553
    You're not pouring the acid in the skimmer are you? Just asking!
    Good question, Bama!
    I usually pour it on the opposite side of the spa from the skimmer near a jet to get it dispersed well before going into the skimmer. Usually needs only about an ounce every few weeks.
    Quote Originally Posted by Ohm_Boy
    Odd.
    That's exactly what it is, only a lot smaller. I don't know why they corrode so quickly but salt water may be a different animal from antifreeze???
    Spoke with the Pentair/Sta Rite tech today.
    His opinion is that high pH is to blame for the repeated malfunctions of the TR.
    pH does drift up to 7.8-7.9.
    Skeptical but I will try to control it more tightly and see if that makes any difference this time.
