Results 1 to 13 of 13
Thread: in-ground spa: any $ savings with a cover? what to get?
    I have an in-ground spa built into a cement pool deck, next to the pool. I know that rigid covers are commonly used with standalone spas. Question: are there any dollar savings to be had by getting some kind of cover for an in-ground spa?
    I have seen floating bubble-wrap "covers", and I've seen thicker closed-cell floating covers on in-ground spas. No idea if any of this is useful. An in-ground spa is probably not as well insulated as a standalone spa.
    What kind of covers do people commonly use for in-ground spas, if any? What do you recommend?
    Thanks!
    60k gallon (est), 83ft PebbleTech pool, spa. Goldline Aqualogic controller, AQL-PS-8. 2 Hayward SwimClear C5025 filters. Hayward H400ED2 heater. 2 T-15 SWG. Pool pump: Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor. Spa pump: Hayward SP4015NS pump / 1.0 HP Emerson 1081 motor (SF 1.4, RPM 3450, Amps SF 6.2-5.8/11.6). Hayward 5060 3/4HP booster pump. 6' x 9' waterfall driven by a Hayward SP4015NS pump (115 GPM @ 47' of head & 2200 watts). Spa jets driven by a Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor (SF 1.6, RPM 3450, Amps SF 11.0 - 10.2/20.4) Still learning!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: in-ground spa: any $ savings with a cover? what to get?
    You would save some money vs no cover at all. Concrete is a pretty good insulator, though I dont know how it compares to the insulation in a stand-alone model.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I can tell you emphatically, without a cover in a concrete hot tub, you will lose a LOT of heat. I spend about $30-60 per month keeping my hot tub running full-time at 70 degrees during the winter. Without the cover, I would just quickly guess and say it would probably run near 5-6 times that not to incude the amount of water needed that evaporates each day.
    I've got a 4" insulated cover that folds over on my hot tub. Never used the bubble wrap, but it would be better than leaving the water exposed. I would highly recommend an insulated cover.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Thanks folks. I'm looking for a source for a cover. Here's one on eBay, but it doesn't look very thick:
    http://www.ebay.com/itm/INSULATING-THER ... 4ab4e972e8
    I'm having trouble finding sources for floating covers for in-ground spas -- there really isn't a lot of discussion about it on the web.
    I have a of large-bubble wrap left over from my move. I suppose I could hack something together using that. Would prefer something a little more finished, though!
    Dec 2010
    560
    I'm curious, why a floating cover? Here is a picture of my cover
    TFT-100 test kit
    Floating cover is not required, XsAllOverIt. A cover like yours would work fine. Mine needs to be round -- looking around online, I've been finding mostly square ones, for square standalone spas. My inground spa is connected via a spillover to the pool -- see attached. What would be a good source for such a cover and what should I expect to pay?
    Dec 2010
    560
    Mine has a very small spillover also. Not sure how the cover would support itself on your spa unless you would some kind of supports between the spillover and the cover? I'm not sure how much mine cost or where they got it. I got it when the pool was built, but I can tell you, it retains a LOT of heat during the winter. It will normally take 3-4 days to go from 100 to 70 in 20-30 degree weather. Where are you located? Is it cold? Your pool is obviously open.
    TFT-100 test kit
    Quote Originally Posted by XsAllOverIt
    Yeah, I'd like a hard cover like yours, assuming I can find the right price and it can be made to fit my tub/spillover. Mine is about 7.5 feet in diameter. I'm located near Sacramento, California. Pool stays open year 'round, the weather here is very nice IMHO. Wintertime nighttime temps can approach freezing, days are anywhere from the high 50s to the high 70s right now. If I had my druthers we would keep the hot tub hot all of the time and I'd be using it just about nightly.
    We only bought the house late last year and I only fixed the hot tub pump late last week, so this is new to me.
    If I could figure out a way to cover and waterproof it, I reckon I could McGuyver something together using rigid foam insulation, a foam cutting wire or knife, a potter's wheel and/or good old Yankee ingenuity. However my understanding is that rigid insulation is open cell and will quickly become waterlogged if not properly covered.
    In the meantime, I have ordered one of those blue bubble-wrap floating covers and a 1/4" closed cell cover. If anyone has leads on something more rigid that would suit our needs, I'd love to hear about it!
    Dec 2010
    560
    I would certainly think you could put a cover like mine on your hot tub if you use some rocks/bricks on the side with the overflow to hold the cover in place. My cover wouldn't work if it got wet. Did a search on google and the few places I looked for spa cover, they had circular covers. Mine is an 8' radius also. I fold mine over twice and usually leave it in place. We use ours about 1-2 times weekly all winter. I keep my hot tub at 70 degrees full-time. I have a 400BTU gas heater and it takes approx. 10 minutes to get it to 90 when we go in and another 5 minutes to get it to 100. I think I save significantly on heating costs by keeping it at 70 degrees due to the fact that it's used infrequently.
    TFT-100 test kit
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I have a hard top cover for an inground spa... Round. I think I paid about $600.
    It doesnt fold and it has a cut-out section for the spill-over.
    But I wouldnt recommend it to anyone because it doesnt fold. Its enormous and I never have any place to put the thing. If I could get the exact same thing as a fold up, it would be awesome.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    I've sent a message to "Spa Cover Direct," which supposedly is a manufacturer of spa covers. We'll see if they have something suitable. If anyone has positive or negative experiences with this company, I'd love to hear them. Link: http://www.spacoverdirect.com/
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I had a positive experience with this company http://www.spadepot.com/shop/Spa-Covers-C45.aspx about a year ago when i needed a replacement round cover for my old hot tub.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    I'm also looking to get a new spa cover and was contemplating this one http://www.hottubcoverdepot.com/prod...over-by-shape/ Does anyone have any experience with this vendor?
