Thread: First test of the year!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Well the weather has been getting warmer here and the water is finally staying around the 59* mark consistently so it's time to check the numbers.
    FC 4
    CC 0
    TC 4
    PH 8.2
    CYA 55-60
    TA 110
    Hardness 550
    Borates 30-50 looks like either...lol
    Salt 3100
    Really impressed with the Borates holding all winter! I thought for sure I was going to have to reaply. My DIY dosing pump seems not to be working so the PH is sky high!
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    30,414
    Re: First test of the year!
    Hey, Max,
    As Tonto used to say, "Long time....no talk"
    Get that pH down, your CH is too high to be flirting with trouble up there in the 8's. I would suggest you hold pH around 7.5 or below for the rest of your life!!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Hey Dave! Been doing allot of reading, not much posting! I like my PH around 7.4, as for my CH, can't seem to lower to acceptable numbers? Was working on a detailed DIY bearing replacement on pumps but it turned into a disaster and now I have to replace my pump before the big KA BLAMO! But I can't get a good answer on how to do it with wiring it up?? Talk to 10 people get 10 answers??
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    P.S. Dave placing a refill order this week!
    Feb 2008
    Denton, TX
    5,061
    Does "hardness" mean calcium hardness? If so, you nee to change out water to lower it.
    550 is above normal but it isn't crazy high. You shouldn't have to change much water out to get it down.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Yes 257, CH. Tomorrow I am going to test my tap water. Last year I drained quite a bit of water if I remember?
