Thread: What adapter?
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    What adapter?
    Well, my old pump finally died and I purchased a new one, which of course has a different fitting for connecting to the sand filter. Below are 3 pics, my old pump, the pipe that attached to it and my new pump. What sort of adapter do i need to make my current piping work with this pump?
    Cheers.
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    Nov 2011
    Pasadena, California
    16
    Re: What adapter?
    Looks like a nipple in the pump volute attached to a threaded union would work
    30,000 gunnite with emerald bay pebble tec
    Pentair fns 60 square feet DE filter
    Whisperflow 0.75 hp pump
    22,347
    Re: What adapter?
    If that's a standard union half on the filter hose then Axell is correct. All you need is a union and a nipple. If it's not I'd change the hose out to rigid PVC all the way.
    Re: What adapter?
    Is that inner threading the right size to connect a pvc end (such as the ones you can buy at hardware stores)?
    the male end of the male+female threaded coupler
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: What adapter?
    A standard 1.5" M/A (male adapter) schedule 40 PVC should connect to the pump.
    I would also add a 1.5" union to make 'playing with' or taking in the motor for the winter a LOT easier.
    If you need any help on sealing the threads or gluing the PVC - simply ask and we can tell you step - by - step what you'll need to get and how to attach the pump to the filter.
    Luv& Luk
    -Ted
