Results 1 to 13 of 13
Thread: Rust?
    Aug 2011
    El Paso, TX
    25
    Rust?
    Hey guys!
    So I decided to "open" (I never closed it) our pool for the season and have been checking components, cleaning, testing, etc. But I've noticed there's what appears to be "rust migration" coming from the lights. Any ideas what it is? Note the very visible trail at the bottom, but also the slight trail moving up on the top right. The pool light has more migration towards the top without the "leakage" on the bottom...
    My current chem levels are as follows:
    CL: 6
    pH: 7.2 (I've been trying to lower TA from 120)
    TA: 100 (hope it stays)
    CYA: 40
    CH: 450 (I finally got my CYA where I wanted, so I'm reluctant to remove water, for now...)
    Any feedback is appreciated. Thanks!
    IG plaster; 32x16x3-5 ft. w overflow spa; ~15k gals; 2 hp Pentair pump; 120 gpm Pentair DE filter; Pentair heater
    Re: Rust?
    There's likely to be something rusting in the light niche. You can pull the light out of the niche and take a look. The light is a sealed unit with enough cord to allow the light to be lifted onto the deck. Don't pull too hard on the cord. Removing the light from the niche should be easy, but there can be complications if the screw is stuck, or if the plaster is not done correctly.
    Sometimes, getting the light out and back in ends up being a problem. Therefore, you have to decide if it's worth messing with.
    Support the site
    Feb 2008
    Denton, TX
    5,061
    Re: Rust?
    May be something as simple as a non-stainless steel screw being used to secure the light in the niche.
    Aug 2011
    El Paso, TX
    25
    Re: Rust?
    Thanks. I'll ask the pool contractor to take a look (still under warranty). I just didn't want to hear "it's mustard algea" from him.
    Jul 2009
    London and France
    574
    Re: Rust?
    Quote Originally Posted by 257WbyMag
    Ha, simple.......to remove
    Aug 2011
    El Paso, TX
    25
    Re: Rust?
    I checked with the contractor. He mentioned this stain is not rust, but rather is caused by the lubricant used while pulling electrical cable during the build-out. Contractor did agree to "fix". However, I'm curious if this makes sense or if anyone else has seen this caused by a lubricant, at least in a pool anyway
    Re: Rust?
    I suppose that it's possible. However, I haven't seen lubricant make such a stain, but most people don't use lubricant.
    Support the site
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Re: Rust?
    Its rust- you can see it. He just did not use a Stainless Steel Screw to attach the light.
    Wire pull is clear, and is water soluble. You can get blue for special purposes, but again it's water soluble.
    Just agree with him and most likely it's an easy fix. Remove and clean the area with a pumice stone or wand type stain remover,
    put light back in with correct SS screw. 15 min fix. Max. It would however be easier if you pumped the spa wveater into the pool before the repair so you would not have to wade or go under water - then when done pump it back into the spa. If you can't easily do it with your valves use a cheap sump pump with a hose attached.
    Just dont turn the lights on with no water - or you will fry your light.
    My guess is one of his workers lost the screw and used a drywall screw of something.
    Seen it done a couple of times before.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Aug 2011
    El Paso, TX
    25
    Re: Rust?
    Thanks. I can drain spa to pool (easy to do w my valves). I'll see what I find in there.
    Aug 2011
    El Paso, TX
    25
    Re: Rust?
    I checked this out, and it doesn't appear to be rust. Check out the pics:
    What is this?
    Re: Rust?
    It kind of looks like rust. I suppose that it could be wire-pulling lubricant. However, if it is lubricant, then it was a poor choice for this application due to the mess it makes.
    Try putting a magnet in the stuff to see if it is rust.
    Support the site
    Aug 2011
    El Paso, TX
    25
    Re: Rust?
    It's not rust. Took a magnet to some of the left over debris, and it didn't stick.
    Re: Rust?
    I really don't know what that is. Perhaps your contractor can provide some answers. Ask him to show you some of the wire-pulling lubricant, including the container that they use.
    You could also open the junction box to see if the other end of the cord is covered in the same stuff.
    Support the site
