Thread: Riviera Pools, Phoenix and Polaris Pop-up question
    Hello, I purchased a pool from Riviera (who went out of business 1 month after my pool was built) that included its proprietary pop-up system. After some research, I'm pretty sure that it is really a Polaris Caretaker pop-up system. Anyways, the pop-up was stuck on one of the 5 pop-ups in the actual 'motor' portion, which is a housing that contains a set of gears and white balls (the balls cover the holes and uncover them when the gear system spins to allow the water to flow).
    So, like an idiot, I took it apart to see if there was something stuck and I cant get it back together. The gear housing will not fully sit back down with the balls in place, but, I cant take the balls out because they are meant to go under the gear housing.
    Does this make any sense? Can anyone help?
    bob
    15k gallon IG kidney pool with attached spa
    plaster
    sand filter
    South Central NJ
    3,192
    Re: Riviera Pools, Phoenix and Polaris Pop-up question
    The gear box is keyed so it will only go in one way, as I recall. If you need a rebuild kit, it is part number 5-9-2001.
    Scott
    Owner of - PoolGuyNJ LLC
