Results 1 to 7 of 7
Thread: Recommendations for umbrellas for my pool "beach"?
    Our pool has two "beaches" -- very shallow areas where a toddler (or adult) can splash around in about 1.5 feet of water. These "beaches" have holes in the middle of them, in the pool floor, to accept an umbrella with a shaft of perhaps 2-3 inches in diameter. Since the mount is underwater, I reckon we'd want this to be an umbrella with a plastic shaft.
    Anyone have recommendations for what type of umbrella to buy and where to buy it?
    60k gallon (est), 83ft PebbleTech pool, spa. Goldline Aqualogic controller, AQL-PS-8. 2 Hayward SwimClear C5025 filters. Hayward H400ED2 heater. 2 T-15 SWG. Pool pump: Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor. Spa pump: Hayward SP4015NS pump / 1.0 HP Emerson 1081 motor (SF 1.4, RPM 3450, Amps SF 6.2-5.8/11.6). Hayward 5060 3/4HP booster pump. 6' x 9' waterfall driven by a Hayward SP4015NS pump (115 GPM @ 47' of head & 2200 watts). Spa jets driven by a Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor (SF 1.6, RPM 3450, Amps SF 11.0 - 10.2/20.4) Still learning!
    Nov 2011
    Magnolia Texas
    80
    Re: Recommendations for umbrellas for my pool "beach"?
    Not sure if this will be helpful or not since your posts are in the water. However, we have been buying aluminum shaft umbrellas for our pool. We have three and switched from wood since the Houston humidy seems to warp those quickly. We purchased ours from Sam's Club for around a $120.00 each. They seem to last about 3 years before the suns gets to them. If you could find a stronger enough plastic shafted umbrella that might be ideal. Good luck.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Jun 2011
    Long Beach, CA
    2,781
    Most umbrellas have either wood or aluminum shafts. Stay away from the wood as the wood will swell up and possibly get stuck in your sleeve. Use a metal shafted umbrella and the cost will mostly depend on the quality of fabric that is used. If you do find a plastic or composite shafted umbrella, they should be fine to use.
    Sep 2011
    Montgomery Texas
    89
    socrates:
    Keep up posted if you find any that work well. I'm in the same boat as you. If I find any I'll let ya know. Steve
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    Feb 2011
    Petaluma, Ca
    665
    I have 3 Costco ones, alum pole, about 6' in diameter +-. A little small but only cost $20 / 30 ea, don't remember exactly.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    For pool use, does it matter what kind of material is used in the umbrella canopy? Is cloth OK, or are your umbrellas plastic, or?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    You could always make yourself a PVC insert to stick above water and pop the 'brella into that. Did that on a picnic table once.
