Results 1 to 16 of 16
Thread: Untangling the mysteries of my plumbing
    JYves's Avatar
    Mar 2012
    California
    6
    Hi,
    Last year I bought a house with a pool and spa and I've been figuring out via trial and errors how to operate it. I had almost everything under control except that:
    - It won't turn into spa or pool mode via neither of the control panels (exterior and interior)
    - It won't control the jets from the control panel
    - I don't know how to have the water circulate to the pool only (I can do spa only and pool+spa)
    - I don't know how to have the jets only.
    It's a Jandy pool with AqualinkRS controllers.
    I've attached a picture to show the plumbing and valves.
    If anybody can help, that would be great!
    JY.
    Feb 2008
    Denton, TX
    5,061
    Re: Untangling the mysteries of my plumbing
    Welcome to TFP!
    We have quite a few automation experts here who will be able to help you. Can you also post a pic of the panel itself?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Did you make sure the actuators are not in the off position (middle on the toggle). The switches are under the actuator itself.
    Mark
    JYves's Avatar
    Mar 2012
    California
    6
    Hi,
    No the switches under the valves are not in the middle position. I actually can control the valves manually using the switches. That's how I'm able to change the circulation from the pool+spa to the spa, somebody showed me that but he did not show me how to make it go to the pool only. And he had no idea why the panel could not control the valves. Here's a picture of the panel.
    JY.
    If the switched move the valves, they must be properly plugged into the controller. Otherwise they would not have power. That means the controller should be able to control them. It is possible that the controller is not configured to know that the valves are there. Have you explored the setup menus on the controller?
    JYves's Avatar
    Mar 2012
    California
    6
    Yes I have explored the menus on the remote controller (inside the house). I don't really know where to look and what should be there. Here's the menu flow on the picture. Where should I look?
    JY.
    JYves's Avatar
    Mar 2012
    California
    6
    Really? Nobody?
    JY.
    30,421
    Really? Nobody?
    Unfortunately, complex automated controllers combining pools and spas are a little difficult to figure out long distance. I am no help at all being a dinosaur who simply sees too many automation issues on the forum to invest in it. Any chance you can get the original PB to help?
    RaviePoolGirl's Avatar
    Nov 2011
    Napa, CA
    47
    Quote Originally Posted by JYves
    My pool is the same way, when the main filtration is on, it circulates the pool and spa together. When it is in spa mode, only the spa is circulating. I don't have anyway to run the pool only. It was designed that way and yours could have been too.
    20,000 gal inground hourglass shape with 7' Hot Tub with overflow; Gunite
    Hayward TriStar 1.85/.22 THP - Hayward cartrige filter- SWG.
    Hayward Gas Heater
    May 2011
    Orange County, CA
    696
    There is a 24V transformer that's purpose is to power the actuators. I'm not familiar with Jandy automation, but I would imagine this transformer would be beside the breakers behind the breaker panel. Is it possible that this transformer has burned out?
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    May 2011
    Orange County, CA
    696
    No, transformer defect is unlikely if the panel comes on. I just checked out the RS Link manual and it shows the single 24V transformer (behind the electronic controller board) also powers the controller. From my view of the photo, it appears to have three pumps, two filters and a heater (or one filter and one backwash tank to collect spent DE media). It's probably best to figure out what each of the valves does first.
    I believe the pump on the left is dedicated to a water feature or cleaner line, and the one in the center is the main filter pump. In front of the filter pump is the suction manifold, with the left side pipe going to the spa and the right side going to the skimmer and/or main drain. The 3-way valve here would control flow in from the spa (handle pointed left) vs. pool (handle pointed right). The 3-way valve in the front right of the suction manifold appears likely to control suction from the skimmer vs. main drain (or balance between two separate skimmers). The return manifold is the one on top. It controls return jets to the spa vs. the pool. It appears there is another pump on the right, and this is probably for a water feature and/or spa jets. I cannot figure how it's plumbed because the control panel blocks the view. It would be helpful if you could take pictures from a couple of different angles.
    Overall, this is a pretty complex setup. It would be helpful to know how many skimmers, water features, etc. Once you have figured out what each valve controls, then it will be a much easier task of understanding how the AquaLink works. If you don't have the manual, you should be able to download this from the Jandy website. I still find it odd that the valve actuators don't function, but this is going to require some careful analysis.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You go through their troubleshooting manual and see if you can find something.
    All of the documentation can be found at this link.
    Mark
    JYves's Avatar
    Mar 2012
    California
    6
    Thanks guys for the advices.
    I already went through the troubleshooting sections of all the manuals but couldn't figure anything out. As JasonLion mentionned, I believe that somehow the controller does not know that the valves are connected. My control panel has a button on the upper right part of it that should toggle the circulation from pool to spa and back as well as pool drain and spa drain. When pressed it goes directly into spa drain and activate the rightmost valve (so the controller knows this one is in). It never goes inot any other mode though. That's why I posted the menu so that someone may know how to tell the controller how to declare a dedicated JVA.
    To give more details on the setting: there are actually 3 pumps: left is for the spa jets, center is the main pump, right is for the water features. 1 skimmer only, 3 waterfalls and 3 jets, controlled by the second valves from the right.
    JY.
    mas985's Avatar
    Pleasanton, CA
    11,737
    So can you manually switch each actuator with the toggle switch back and forth? If so, then it must be a programming issue.
    Mark
    JYves's Avatar
    Mar 2012
    California
    6
    Quote Originally Posted by mas985
    Yes. But how to program the controller?
    JY.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you read the manual? Also, Zodiac I am sure would help you out if you call.
    Mark
