Results 1 to 9 of 9
Thread: digital pump timer needed
    Apr 2010
    Southern California
    83
    Hi everyone. I am searching for a new digital timer to replace the analog timer that I currently have. I only need something basic as I will only have it turn on once or twice a day at most, but I was also like it to be very simple to manually turn on and off for when I want to clean or add chemicals.
    Here is a photo of my current timer:
    I would like to keep it to $100 or less if possible
    Thanks for your input!
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Feb 2008
    Denton, TX
    5,061
    Re: digital pump timer needed
    What are you running aside from a pool pump? If that's it, I would probably just go with a basic Intermatic mechanical timer.
    Feb 2012
    Stowe, VT
    59
    Take a look at this one. Verify before buying of course!
    http://www.amazon.com/Intermatic-EH10-1 ... 50&sr=1-33
    (Edit) this model is 120v
    As a note if you did not know. That silver tab at the bottom right of the dial is the on/off switch.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    Apr 2010
    Southern California
    83
    The pump is the only thing running off the timer. The reason I wanted to go digital is because I would not have to mess with the tabs and I could set for more than one time in the same day. The analog timer has been very inconsistent for me...now more than ever, which is why I'm replacing it.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Those digital timers are great. Buy another set of tabs from the hardware store (only a few dollars) and they can be turned on and off more then once.
    If you want to go digital at a low price look at this one.http://www.amazon.com/gp/product/B000NC ... 00_details
    It is the same as the one posted by Linktefur but 240v - I'm not sure witch you need.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Apr 2010
    Southern California
    83
    So it doesn't matter that the timer says it is for a water heater? I definitely like the price for it.
    I'll verify, but I think I have 220v there since there appear to be two "hot" terminals, one nuetral and one ground.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Quote Originally Posted by Uncle Ben
    Correct. It does not matter what is being timed as long as voltage and amperage are right.
    Jandy 2 speed pump
    Feb 2012
    Stowe, VT
    59
    Quote Originally Posted by texasdad
    Exactly, you can use a timer for lights, heaters, pumps, motors, or HVAC systems. You can use it to turn power on and off to solenoids on water fill or chlorinators (much less popular but still applicable.) Endless options, but you have to have the right timer for the right job.
    Please have a qualified electrician make the connections if you are unsure whatsoever. It's not worth frying yourself or your equipment!
    May 2011
    Orange County, CA
    696
    Also, add GFCI protection to that circuit. It looks pretty old, and GFCI protection is not only required by code, but a good idea. Should the pump ever experience a short, this is good protection to protect against electrocution for anyone in the pool. The same goes with pool lights. They should also be on a dedicated GFCI protected line. This can be accomplished using GFCI breakers or in-line GFCI modules.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
