Thread: Is my liner ruined??
    Hello folks... I have a problem. The wide strap halfway down the pool that wraps around the "belly" of the liner had been chewed up my mans best friend...
    Is there a fix for this or will i be draining and replacing my liner this year?
    I have the blue 18' Intex.
    Any thoughts?
    Thanks
    Dave
    Feb 2012
    Phoenix, AZ
    728
    Re: Is my liner ruined??
    Hey Dave, I've got a couple questions about your liner.
    Is it chewed all the way through?
    If possible, pictures would help us get the best idea of whats going on, and what you can do to fix it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by digitaldave52
    Welcome to tfp digitaldave52!
    Where do you live? Is your pool frozen (like mine)? If it is or even if it isn't but still holding water, I would think you could repair/replace the strap. If it isn't frozen, you may have to reduce the water level so the strap is the right diameter when placed, then refill. If the liner is not broken, you should be able to reuse it. Those Intex liners are not like most AGP liners where once you drain they typically need to be replaced, the Intex seem to handle (and are designed to handle?) draining. Got any pictures?
    I'm in North Carolina, so nope, no frozen pool here. (at least not this year)
    The strap is chewed completely through but the liner itself is undamaged and holding water.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Some rolled up newspaper for the dog and some Gorilla brand duct tape for the strap and you'll be as good as new.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Last year someone posted where they used a heavy duty towing strap and a wratching winch to replace a busted liner strap on their intex pool.
    Love TFP? Become a
    TFP Supporter!
