Thread: Solar Heater Plumbing?
    Hi, my pool builder is installing 38' Moroccan fiberglass pool in April. This is a "basic" installation, e.g. no spa, no heater, etc. I know I will be installing solar panels next year. Should I have the PB plumb for the solar feed/return with valves now or should I not worry about it until I cross that bridge?
    Question #2: Control is EasyTouch 4 w/ic40, can I use the ET to automatically setup run times for the solar heater? If so, how many actuators would I need and what would be the basic plumbing?
    ...just tying to think ahead...
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    22,553
    Re: Solar Heater Plumbing?
    It really doesn't matter if he installs the stub outs or not, but do make him aware of it so he can route the plumbing so you don't have to completely reconfigure it when you get ready to install the solar.
    I can't answer about the automation but you'll need at least 2 actuators for the solar. You can get by with one on a three-way valve, but using two is better IMO.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,071
    We only have one three way actuator( GL-235 controller), however we do not have full automation. Like dave said 2 actuators would be better. Look at our solar install in the sig bar to give you ideas of set up. Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
