Thread: Pump disconnect
    Pump disconnect
    I am installing a new Pentair Intelliflo pump and due to it's cost and only 4 months of use here in NE-PA I thought I'd bring it in the house when the pool is closed up. My question is, is there a good option for a disconnect that can be used? The pump station is 50 feet from the pool and the ez touch breaker box is 4 feet from the pump. The pump will be on a 240 volt/20 amp circuit. I can easily use a DIN disconnect for the rs-485 connection.
    I have two other larger 5 HP pumps for the swim system and I'm considering bringing them in also and each of them is on a 30 amp circuit.
    john
    Northeast PA (Mt Cobb) 16,000 gallon in ground salt pool with all Pentair automation and Intelliflo VS pump. Also part of the pool is a two 5-horsepower 3-jet Badujet swim system. For heating we use a 384 sq-ft Heliocol solar pool heating system and additional solar from the 160 sq-ft house solar heating system.
    22,553
    Re: Pump disconnect
    You can use twist-lock connectors for the pumps if your jurisdiction allows it. The NEC allows plug and cord connections with a cord no longer than 3'. You can't plug the bonding conductor though. You'll have to mechanically disconnect it each time.
    Re: Pump disconnect
    Do they make a water tight twistlock?
    22,553
    Re: Pump disconnect
    Here are marine versions of them.
