Results 1 to 8 of 8
Thread: Reparing fiberglass stairs
    Oct 2011
    Charlotte, NC
    120
    I have a large and very strong retriever who has chipped my fiberglass stairs by standing on them and pushing off to chase tennis balls in the pool. I have three pea sized holes in the first layer of the fiberglass. They are not causing water loss however they look terrible and have fairly sharp edges.
    Is there some type of white epoxy product I can use to fill them? I considered draining the water below the step and using white silicone just to fill them but I'm sure it would discolor quickly and probably not hold long. Any suggestions would be greatly appreciated.
    8000 gallon outdoor inground vinyl. Sand filter, Hayward 1HP.
    38,290
    Re: Reparing fiberglass stairs
    You could try a boat hull gel coat repair kit. I have used them to repair chips out of the bottom of my jet skis.
    Oct 2011
    Charlotte, NC
    120
    Quote Originally Posted by jblauert
    Ok, that's an interesting suggestion. Would this product be available at a marina only?
    38,290
    Any boat shop probably or order online. Google "gel coat patch" or kit. It is a gel/paste that you apply to the hole/scratch and then use a film pressed over the top that smooths it out ... no sanding required. Some of the kits have colors that allow you to mix to match your hull although I see some that are just white which is cheaper and probably all you need.
    Are the holes all the way through or just chips? I am not 100% sure how well it would work if it is a hole all the way through.
    A picture might help a bit.
    Oct 2011
    Charlotte, NC
    120
    No the holes are not all the way through, just through the first layer and there is no water loss. I will try to post a picture later. Thanks.
    38,290
    Odds are you could probably find some white epoxy at a local hardware shop that would work too. I just know the gel coat kits are made to have no problems underwater. Some can be applied underwater as well.
    PC-11 works well for that type of repair. It's white and it's made for marine use. Do it dry for the best results.
    http://www.pcepoxy.com/our-products/pas ... /pc-11.php
    Support the site
    Oct 2011
    Charlotte, NC
    120
    I just ordered a small tube of the white gel coat repair. I saw some that could be applied underwater but since I only have to drain a foot or so of water to get to the step I will just do it dry to get it right. I will post before and after pictures in case anyone else has this issue wants to see how it works.
    Thanks so much for your help.
