Results 1 to 16 of 16
Thread: What do you think the cause is?
    This is a friends pool. They just moved into the house in Octobor so they don't know the history of the pool.[attachment=0:3kap7r6h]untitled22.JPG[/attachment:3kap7r6h][attachment=1:3kap7r6h]untitled1.JPG[/attachment:3kap7r6h]
    Re: What do you think the cause is?
    The pool was only half full of water. Is it possible the liner pulled the wall in?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Candi
    Probably the cover did.
    The cover?? Ohhhhh, it filled up with water, dipped too much and pulled in the walls. Got it.
    22,550
    Did this happen before or after they moved in.
    The problem with the cover pulling it in is that it looks like the cover is still attached to the decking.
    This happened today, they moved in last October.
    22,550
    It's hard to say but without more info I'd have to agree with JT.
    Nov 2011
    Moberly,MO
    1,010
    If the top rail is still in place and only the wall folded over it has to do with liner pull. If the top rail went over that means the cover was pulling too hard and collapsed the wall support structure.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Mar 2007
    Coastalish 'down easter'
    4,160
    OUCH!
    I don't have an answer that fits this, at this point - but let me walk you through what I'm seeing from the pics. (maybe someone else will be able to fit the pieces of this puzzle together)
    Looking at those pics, I see that where the wall failed is where the cover was firmly attached to the deck. (eventually, the cover managed to come off the round ends of that oval pool - but didn't in the damaged area of the wall) This makes me think that the cover was equally secure on the other side - OR that any 'under the cover' air pillows had drifted to that side.
    I assume that most of the cover was secured by a 'cord and winch'.
    Furthermore, I assume you had weather like we've had - i.e. last week we got ~1' of snow dumped on us and then,this week, we've had the past 2 days in the 50s & 60s, resulting in a big melt off, with the result being that there was a good bit of water on the cover. (BTW- kudos to your friends for keeping the cover clean and debris free )
    This doesn't explain why the water on the cover became so heavy as to wreck the walls before being released. For this to happen, I suspect that a major hole/ tear in the liner just occurred. Somehow the pool lost a lot of water, in a short period of time, which resulted in the water on the cover being heavy enough to wreck the wall
    If the other areas around the pool are ~ dry, look for a big puddle around the pool to see ~ where the liner failed.
    Knowing where the liner failed is ~ useless now but, it may help them in the future. [This assumes that they will replace the pool]
    I'm sorry this happened!
    I hope you will continue with this thread and post more pics, as the reason for this wall failure unfolds.
    Luv& Luk
    -Ted
    Nov 2011
    Moberly,MO
    1,010
    It has nothing to do with the cover as none of the top rail has fallen. It is strictly wall failure or liner failure
    Mar 2007
    4,160
    Quote Originally Posted by swimcmp
    I have reconsidered my hypothesis that it had to be a sudden loss of water. A slow leak could have drained the pool enough that the cover water eventually had to give, at it's weakest point, and with a sudden thaw - any buoyant ice would quickly be gone.
    Now I ask you to reconsider your position. The affected area of the wall is where the deck is. I think it's likely that the uprights and attached coping are secured to the deck. When the cover tried to pull into the pool, it put stress on the walls and liner but found no relief where the deck is. With nowhere else to relieve the pressure, the wall crumbled at the deck, pulling itself out from under the coping and toprail, alleviating the pressure while leaving the wall there wrecked.
    Alternate hypothesis - with the cable drawing in on all other areas of the pool, the rest of the pool bowed in everywhere but at the deck. Because the rest of the pool could flex inward, and the area at the deck remained upright, the walls under the deck bowed out enough to get the toprail out of the track. Once freed from the track, the weight of the water on the cover (which hadn't been relieved yet) crushed the walls. (look at where the 2 crumple sites are... in between where the cable is fully secured to the deck). It's where the cover was most secure and where the weight would be greatest.
    Hey, as always, just my $.02.
    Luv& Luk
    -Ted
    Nov 2011
    Moberly,MO
    1,010
    Waste we have seen this a couple times before the cover has nothing to do with it. The wall gave but the toprail stayed that means the cover didnt pull on it. One other option is a burst of wind if that side is unprotected. The wood deck would have acted like a wind tunnel.
    Mar 2007
    4,160
    Thanks for the educated response, which mine wasn't - I have had limited dealings with AG pools.
    I do find it interesting that this must be an inherent problem with AG , or oval AG, pools. We don't know the manufacturer so must assume the problem is in the design and not, per se, the materials.
    I'm not 'baiting' you, I'm trying to figure out if there is some way this problem could be avoided in the future and what the causes may be.
    Luv& Luk
    -Ted
    Nov 2011
    Moberly,MO
    1,010
    I understand that. The problem isn't a design flaw. It is just something that happens from time to time with an aboveground. Conditions just had to be right.
    Dec 2010
    San Diego, CA
    1,137
    So can they just replace the damaged panels or do they need a whole new pool?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Nov 2011
    Moberly,MO
    1,010
    Unless they know who the original mfg is of the pool probably would have to replace it all. Just because it is a said size mfg to mfg doesn't measure out the same for some reason. Sorry to say but that is past experience.
