Results 1 to 7 of 7
Thread: Backwash water for irrigation?
    Jun 2008
    Marana, AZ
    347
    I live in a desert area (outside Tucson) and have no landscaping near my pool. Since we live in an area that gets a grand total of about a foot of rain yearly, I was thinking if possible, it would be good to use backwash water to irrigate and therefore have some green stuff. Does anybody do this, and if so, what can survive the chlorine? I know it doesn't seem to kill the weeds!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Backwash water for irrigation?
    I water my lawn with pool water, and it hasn't seemed to hurt it any. I don't use backwash water, but I have a DE filter. I suppose a sand filter would just be discharging the same dust that's already on the ground without adding any filter media, so it should be okay. I don't have a SWCG. I don't think a lawn would like to be salted repeatedly.
    Apr 2010
    Buckeye, AZ 85326
    619
    Go for it. I know chlorine doesnt affect bermuda or winter rye grass. I have Vincas in my landscape and around my pool that can survive just about anything. I even dump my salt water aquarium water on them when I do weekly water changes with no issues.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Not a problem. I run my backwash on the lawns and trees. A properly maintained pool has less chlorine in it than what many municipal drinking water systems provide from the tap. We also add salt to our water for "feel" and have noticed no adverse effect on the vegetation.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    I also have a question on this, is it possible to irrigate from the backwash through a sprinkler or would the water pressure be to great if so how could i irrigate it so that the water is distributed over a larger area?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    No reason you couldn't hook up a sprinkler, but you wouldn't get much backwashing done...I think it would slow the flow rate down too much.
    Richard320's Avatar
    Jan 2010
    18,985
    Quote Originally Posted by Jason0046
    Two people with cell phones is how I've done it. I hook up the backwash hose and get it in position, then call my wife and have her throw the switch while I play fireman with the hose and spray the front lawn with it. If it needs to be shut down fast, she's on the phone, and standing next to the switch.
    The fibreclear didn't clump up or smell. If anything, the lawn seemed to appreciate the fertilizer.
