Thread: Long solar temp sensor wire ???
    38,245
    Planning on putting a controller on our solar system. House is ~75' from equipment pad so the 15' 20GA wire that seems typical for the temperature sensor is obviously not going to work.
    In the Hayward manual I see the note "For long runs or runs near other electrical wiring use shielded cable (Belden 8428 for outdoor use)". A quick Google reveals that 8428 is a shielded 18GA twisted pair typically used for audio microphones and a 100' length is > $300 That seems a bit excessive for a $20 sensor. Unfortunately, there is really no good place closer to the pad.
    I understand that there is more resistance as the wire gets longer but is this really necessary?
    Does anyone out there have a sensor run close to 100' and what kind of wire are you using?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Long solar temp sensor wire ???
    Just do a google shopping search for 18 Ga Shielded twisted pair, and you will find plenty of sources MUCH cheaper than that
    LMGTFY
    CLICK HERE
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    22,542
    The reason it calls for the 8428 is that it has a braided shield. Most shielded cables use a foil shield or are not 100% shielded. Do you need a braided shield? You don't really know until you've installed it and you have problems. If you're not running it in close proximity to AC power I'd say the foil shielded would be fine.
    Most electrical supply or industrial automation houses carry twisted shielded pair cable. 16 or 18 awg will be fine. Whichever they normally carry in stock.
