Results 1 to 12 of 12
Thread: Liquidator
    Liquidator
    Hi all, wanted to see how those who have the liquidator like it?
    Worth doing?
    Pros cons?
    Thanks in advance!
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    Liquidator
    Also meant to ask... Is there something newer/better out that won't break the bank?
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Liquidator
    Quote Originally Posted by Highlandreef
    I have no firsthand experience with a liquidator, but last summer I considered one and read many post about them. It seemed to me there were lots of problems with them and people were doing all sort of modifications to make them work.
    A peristaltic pump is only a little more money and works great. http://www.uswatersystems.com/shop/cate ... %26-Parts/
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Liquidator
    I've had one for 4 seasons and it's been great. I'd get another one tomorrow if mine quit.
    Liquidator
    JohnT, did you have to do anything to yours to get it working?
    Texasdad, I checked that site and offhand I am not sure what pump to even look at, they have low pressure, high pressure, etc, etc.
    It sounds like you have one, what do you have on your pool? Mines about 18k gallons or so if that helps.
    Thanks boys!
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Liquidator
    This is the pump I have:
    http://www.uswatersystems.com/shop/prod ... -Pump.html
    here is the same pump with the tank already attached; but you can find a different tank for much less money then this one:http://www.uswatersystems.com/shop/p...nk-System.html
    You want a high pressure stunner pump. They are sold by the number of gallons per hour they can pump and also adjustable or fixed rate. If you have it on a timer then you can do fixed rate and adjust the chlorine amount with pump run time. Or an adjustable pump can be on when your pump is on and you control the flow rate of chlorine. Figure out what the most amount of chlorine you'll need to add in a day at the peak of summer and how long the pump will run each day to determine the pump size you need.
    Jandy 2 speed pump
    SW Indiana
    9,199
    Re: Liquidator
    Thanks boys!
    Nothing modified on mine. As long as you have some filter pressure it usually works out of the box. Sometimes AG installations have a little trouble getting enough flow, and it needs larger tubing. No big deal.
    22,551
    Re: Liquidator
    I've had both and I added the 3/8" upgrade and a needle valve to the LQ (liquidator). It worked great except that I have tons of oak leaves and when they filled up the skimmer it would affect the flow so I was constantly adjusting it. If you don't have leaves it would work fine. I now have the Stenner peristaltic pump and it is pretty close to set it and forget it. You have to test and check the operation regularly just as with anything else.
    In the end, I'd heartily recommend both.
    Liquidator
    Thanks to everyone!
    This place rocks!
    I have to say I like set it and forget it
    22,551
    Re: Liquidator
    Just don't be fooled, you still have to test and adjust when needed and you have to be diligent and not let yourself fall into a false sense of security. That's true no matter what system you have.
    Jun 2011
    Hampton Roads area, VA
    56
    Re: Liquidator
    Hi all,
    I've been off the site over the winter but with this early spring rolling I figured I'd better get back on the pool train! As before, this is the site to get the best answers for EVERYTHING poolesque.
    Thanks for posting the opinions on the Liquidator. I'm considering getting one, too. My concern is that I'm not experienced at all with pool plumbing (or plumbing in general, for that matter) and don't want to mess up my functioning system. From a truly newbie stand point, is the Liquidator something relatively straightforward to install?
    Also, is there another delivery system like the Liquidator that people like?
    Thanks!
    12.5K gal, Pentair Plus DE filter (FNSP48, 120gpm flow rate), IG, Vinyl, 1 HP WhisperFlo pump, Polaris 280 cleaning robot with booster pump
    Pool store!? We don't need no stinkin' pool store...
    Jun 2011
    56
    Re: Liquidator
    Upon reflection - sorry for being tacky and stealing the thread. I'll post my comments on a new post.
