Thread: Filling in pool after replaster
    Dec 2011
    Charleston, SC
    100
    Hi! We are replastering our pool and I was curious if its a lot of money to fill the pool in from empty. Is there an economical way to do it other than just turning on the water? Thanks!
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Filling in pool after replaster
    Sometimes your local water authority/company will charge you for fresh water only instead of charging for both fresh water and waste water since you won't be flushing this water. Try giving them a call.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Your rates are about $1.55 per ccf (hundred cubic feet) for fresh water and $6.59 per ccf for sewer. Your pool holds 33.3 ccf (24,907 gallons). That means that you will pay about $51.62 for the fresh water.
    The sewer looks to be capped at 18 ccf, so you will only pay for the amount over your other usage but capped at a total of 118.62. As was noted, you can contact the water company to see if there is an allowance for filling a pool.
    Reference
    http://www.charlestonwater.com/download ... report.pdf
    If you have a well, that might be cheaper, but it will often not be worthwhile unless the water is very good.
    Support the site
    30,431
    Adding emphasis to the last part of that statement, I would suggest well water as a last, least favorite option. A very high percentage of pool water issues we see here on the forum comes from high iron content well water.
    22,553
    Also adding to the well issue. Most wells won't handle pumping enough water out of them at one time to fill a pool. They'll usually run dry before you get that much water out of them. Just something to be aware of.
    Dec 2011
    Charleston, SC
    100
    I just called the water dept and they do offer a bill adjustment! Thanks so much everyone!!
