Results 1 to 10 of 10
Thread: Intex Pool Clearance
    Feb 2012
    Hoschton, GA
    27
    Hi Everyone. This is my first post...
    How much clearance do you need for an 18' round intex? I know what the manufacturer says but what is the absolute minimum needed? My house is on a steep hill so there are very few areas where I can put a pool. My wife won't let me sacrifice any trees so I decided to go with a round intext to avoid having the side supports (such as on an oval pool) stick out into a tree.
    Also, a small river cuts my backyard in half. If I put my pool near the river, is the permit inspector going to give me any trouble about draining the pool near the river?
    Thanks for your help!
    22,553
    Re: Intex Pool Clearance
    You could probably get by with 19 feet but that's gonna be pushing it. And you're gonna have to have a place for the pump and filter.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    I wonder if perhaps you might get some leeway since the permit guy may consider the Intex/ABG setup as temporary/seasonal and therefore, not subject to the same rules as would be an inground?
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Check with your city, in my city, the intex pools are considered "nuisence" or "toy" pools and do not require permits. That said, you are best to try and follow any rules/regulations as they are for your health and saftey. Not sure what type of clearance you are looking for, for my 18' I cleared out and leveled a 20' circle. I have mine in the corner of my yard 3' from the fence on the south side and about 6' from the west side. Here is my build http://www.troublefreepool.com/plann...cs-t12625.html
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Feb 2012
    Hoschton, GA
    27
    Thanks for your input! I think 19 feet might work. The clearance issues are with trees so I'll have room for my pump. The other issue is the distance of the pool from my house. I ned to figure out a good way to get the electricity across the yard. I was thinking about burying an extention cord in pvc conduit. Can I do that?
    Feb 2012
    Hoschton, GA
    27
    Quote Originally Posted by mcoonan
    Thanks for posting! I did check with my city and they said they do not have authority and to check with the county. The county told me that I do need an inspector...mainly to make sure I don't set in on the septic tank. Also, there is the elctrical hazard. That's a beautiful build! I think I can make 20' work...I just don't want the inspector to give me trouble over the pool being so close to the river bank. It will be about 20' away...
    Feb 2012
    Hoschton, GA
    27
    Quote Originally Posted by 257WbyMag
    Welcome to TFP!
    Thanks for the warm welcome! I do hope the inspector is reasonable...maybe I can take some pictures of the proposed location and have you guys give me your opinion before I call him out to the site!
    Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Quote Originally Posted by CSimpson
    If you have to have an inspector look at things they most likely will not pass an extension cord buried in conduit. Check with an electrician and find out the cost to have a plug installed near the pool. Another option if you plan to upgrade the pump and filter, is to buy a longer power cord, and tell the inspector it will be unplugged when not in use.
    Love TFP? Become a
    TFP Supporter!
    Feb 2012
    Hoschton, GA
    27
    Quote Originally Posted by zea3
    Thanks for the heads up. My only problem is that the only place I have for the pool is probably a good 80 to 100 feet from the house. Having an electrician run that much wire will be very expensive...
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Find an electrician that will work with you. You run the wire and they do the connections if you are not comfortable doing so. Some PVC, glue and a spool of wire is fairly inexpensive but labor intensive. Most electricians hate digging anyway! LOL
    Aquabot Pool Rover
