Results 1 to 10 of 10
Thread: Question about filter
    Mar 2010
    Spring, TX
    1,082
    Ok I had not backwashed in a while and the pressure was up to about 15, which is about 8 over clean filter. So I cleaned it out and it only went down about to about 10 which is not usual. Usually after a backwashing it goes down to around 5. I let my pool go so I knew I had some algae so I started the shock process. Raised my FC up to shock level and after a few days or so the pressure was back up to pre backwash and very ligh pressure coming out of the jets. So I backwashed again today to maybe get out whatever was in there and my pressure only went down to around 10 again which is 5 more than what normal was when I did al prior cleanings. When I was backwashing the water never came out dirty. It was clean from the very first backwash. I tried about 5-6 more times with backwashing and back to pump and each time the water came out clear. Every other time in the past I have seen DE come out when backwashing. After this backwashing the pool went from semi clear to cloudy. I figured that was just from backwashing and pumping into the pool. So I added more DE and there is no DE on the bottom of the pool so it does not appear there is a leak or tear in a filter. My filter is about 20 years old or so and I have it sealed off to where when next time I open it up it will need to be replaced as part or almost impossible to find. I have been to 2-3 pool stores with 1 of them being a mom and pop store and trust his judgement completely.
    So does anyone have any reason why this may be happening? Do you think it may be time to replace the filter?
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,548
    Re: Question about filter
    Does the gauge go to zero when the pump is off. I'd suspect the gauge first.
    Mar 2010
    Spring, TX
    1,082
    Yes it drops down to 0 without a problem. Watching when I turn it off it does not delay and falls right back down to 0. I replaced the gauge about 5 months ago so fairly new. In order to replace it I would need to take it apart and that is not an option unless I want to replace the filter. I only think it may not be the gauge do to the week output from the jets which is in line with the high pressure on the gauge.
    Thanks.
    Mar 2010
    Spring, TX
    1,082
    The water could also still be cloudy because I have not passed the OCLT yet. It is weird when the water is clear you can still have stuff in it. I lost 4 ppm the other night and last night 3. So that could be the reason why the water is not super clear.
    I am used to this clarity.
    who-is-ready-to-swim-t29479.html?hilit=ready
    Mar 2010
    Spring, TX
    1,082
    Well I got home tonight to fine some fine white looking dust at the bottom, which may have very well been DE. We shall see.
    22,548
    It could also be dead bleached out algae. That could also be the reason the filter isn't backwashing cleaner than it is. Once you pass the OCLT, it might be time to break the filter apart and give it a good cleaning.
    Mar 2010
    Spring, TX
    1,082
    Well breaking it down is really not an option. I have used a ton of silicone sealant on it and last time I broke it down things start coming apart on it. So I am trying to make it last as long as I can. The only reason I think it is DE is it is very similar to last time DE got into my pool and it appears to look exactly the same. The water is getting a lot clearer and my loss is getting smaller. Last night it was around 1.5 so making progress.
    22,548
    Even if it's DE getting back into the pool you're going to have to tear it apart or replace it to ever fix the problem or it'll just keep getting worse.
    What to do?
    Mar 2010
    Spring, TX
    1,082
    What to do?
    Yea I know and that is my problem, what to do. But maybe you are right it was just dead algae. I just vacummed it all up so we shall see soon.
    Mar 2010
    Spring, TX
    1,082
    Well bit the bullet and bought a new filter. I added conditioner to the skimmer and soon after it was all back in the pool via the jets. So new filter is getting installed on frida Hayward C5025, wich is a step up from what I have now. Now will be easier to clean as well.
