Results 1 to 11 of 11
Thread: Replace pool pump motor
    i need to replace my pool pump motor (i think) and was thinking i would try to do the work myself. Doable? Or should i get a professional. I am pretty handy and can manage most home improvement projects.
    any advice would be greatly appreciated.
    thanks
    16k gal., Pebbletech, Pentair IntelliFlo VS, Hayward Navigator, Pentair Suntouch, Sandfilter
    22,550
    Re: Replace pool pump motor
    Replacing the motor is not too bad a job. If you're handy and have the tools, you can easily do it. You'll need a new seal too.
    There's a post that outlines changing the seal on a Whisperflo. Even if yours isn't a Whisperflo it'll be close enough to help you along.
    thanks for the tip. any idea the cost of new motor?
    22,550
    Without knowing what pump you have or where you're located and if it's a 1-speed or 2-speed I'd say $150 to $250. If it's not a 2-speed you should consider getting one. It'll help on your electric bill.
    thanks again for the help. the pump motor is so old cant read the HP detail. i guess i can take apart and take to pool supply store to find out.
    do impellers go out very often?
    Feb 2012
    Phoenix, AZ
    728
    It is much more common for a motor to go out than an impeller (but it can happen). Also, you should compare the price of a new motor (and seal) to the price of a new pump. Like Bama said, upgrading to a 2-speed from a single speed will save you money in the long run. If you take some pics of your pump, I am sure someone here can help identify it.
    22,550
    Not very often at all. About the only time you lose an impeller is from mechanical damage.
    thanks for all the help guys. could it just be the capacitor? when i flip the switch to turn the motor on it hums for a few seconds and then kicks off. after 5 minutes this happens again until the time between "hums" gets to be significant. could this be the capacitor or is this what a dying motor sounds like.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Sounds like the start capacitor. If you search Youtube for replacing start capacitor on pool motor you should find some good info.
    how about capacitor?
    22,550
    It's pretty common to lose a cap. We see it a lot on the forum. Most "my pump is humming" threads wind up being the cap.
