I'm kinda new to looking after my pool, and have a few questions, and advice if possible.
I have a salt water pool, got the water tested and all is good, except I've been having alot of algae problems that never seems to go away. It's pretty bad on the bottom and sides, with some black spots too.
From adding super chlorinate, and algae liquid, the pool turned a more cloudy aqua and so after a day I started to brush the pool. From doing this, the water got extremely cloudy and the bottom wasn't visible anymore which had a more dark green colour. This is basically a cycle that never ends.
Considering I have a salt pool, isn't chlorine not recommended by much usage regarding algae control? Also, I've read you should vacuum through the waste and not the filter... How does that work? I usually vacuum, then backwash, rinse, then back to filter.
Sorry for the basic naive questions :?
Cheers,
Cheers,
