Thread: How big / powerful? Pump/filter combo
    We are in midst of big renovation for 30,000 gallon inground pool. Contractors will replace all equipment and I just wanted to run specs by you all to make sure they aren't cutting costs.
    For the pool, they have a 1.0 HP Jandy PHPF (+5 deck jets)
    Filter is being changed from a sand to Jandy CV 340.
    Is this enough HP and area for the pool + jets? Also, we have bedrooms above the filter and I want to be sure it's as quiet as possible. Would you recommend a stealth? DO we need water feature pump separate?
    Thanks in advnce
    Charlotte, North Carolina, 30k, in-ground concrete (built 2001, remodeled 4/2012), PebbleSheen Blue Aqua, Polaris 360, Jandy 1.0 HP Dual Speed Stealth Pump, Stenner Pump 45MHP2 220v - 1/4" black tubing mounted on 15 gallon UV Gray tank, Jandy CV340 CF, CMP deck jets x6. TF-100.
    22,544
    Re: How big / powerful? Pump/filter combo
    Since you have noise concerns I'd look at a variable speed pump. Those are going to run the quietest. Other than that, the items you have listed look ok.
