Thread: Opening Salt Water Pool in Spring.. what chemicals do I need
    I am opening my salt walter pool sometime next month. What do I need to get. I have the following
    some bottles of Liquid Stabilizer/Pool Water Conditioner
    When I had just regular chlorine pool I knew the chemicals I needed to throw in to make the pool swim able after a few days for things to settle down. Do advise. Thanks.. I have the $70+ Salt water Tester Kit someone here told me to get and I have been using it ever since.
    I have to add water... then Salt, then do I add the Liquid Stabilizer/Pool Water Conditioner after the salt or before the salt. As before ... when I forgot to add the Liquid Stabilizer/Pool Water Conditioner... the salt kinda went away within less than a week and I had to keep adding salt.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Opening Salt Water Pool in Spring.. what chemicals do I
    You STILL have a chlorine pool! Only thing has changed is the need for salt per your generator requirement and a tad higher CYA level.
    I guess I should shock it or purchase the kit from intheswim then? Thanks
    30,432
    Spend some time up in Pool School reading those articles and that will help you begin to gain an understanding of how to care for your pool.
    22,553
    Quote Originally Posted by pectin232
    The salt doesn't go away except by water loss.
    The first thing to do is run the pump and then get a full set of test results. That will tell you where to start and what you need to add if anything.
