Thread: pool light full of tar-like substance?
    Jul 2009
    Kingsville, TX
    8
    Hello all,
    In my quest to make every mistake a pool owner can, I decided to replace the non-working light in my in-ground pool. I unscrewed it, got it to the surface, and saw that water seemed to have gotten into the light and wreaked havoc. I unscrewed the six screws holding the face plate and lens to the body of the light and discovered a great glob of black glop within. It looked almost like it could have had a waterproofing function, but it was massed up against the lens instead of being packed in around the hole for the wiring, which is where I imagine the fixture may have needed waterproofing.
    My question is, is this tar stuff normal, or have I discovered an old "repair"? If I'm going get this thing working again, should I try to replace the bulb (which was burnt) and gasket, or should I buy a whole new kit to be rid of the gunk altogether? Thanks for your help.
    18/20x40 free form in ground 30,000 gal gunite sand filter, 1.5 hp pump with antique Polaris cleaner
    30,431
    Re: pool light full of tar-like substance?
    Typically, there should be not glop of gunk in there. Is it slimy? It could well be something growing.
    Jul 2009
    Kingsville, TX
    8
    It's extremely sticky. I'm thinking maybe it was once epoxy meant to seal the back end of the fixture but it melted? There's maybe a cup of it.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Sounds like someone spread in some mastic or something, maybe to replace a missing gasket?.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Ohm_Boy
    I'll bet that you are right. I certainly can't think of anything else that it would be.
