Results 1 to 11 of 11
Thread: Anyone successfully shocked a green pool with pump off?
    My pump is out of service due to some major re-piping.
    Curious if any Pros or others have ever tried to shock a green pool with the pump off? Will it work?
    My water level is drained down 30" for the winter and I want to get the water clear for some leak testing on the pool structure.
    Please let me know if you have succeeded at turning a pool from green to clear with no circulation?
    30,427
    Re: Anyone successfully shocked a pool with pump off?
    plaster or vinyl? it makes a difference.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    You can add chlorine and mix it in manually using a pole brush or leaf net, anything that helps you move the water around, but you cannot get the water clear without filtration. Those dead algae have to go somewhere.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    I didn't have to shock, but I did keep my pool clear for a month when the pump busted by using liquid chlorine and then brushing the pool to mix it in. Since your pool is green, you won't be able to filter out the debris so the water may stay cloudy after the algae is dead. Some folks have also used their manual pool vac and used siphon action to vacuum to waste, that could clear out some of the debris.
    Or you could get a used "trash pump" and temporarily plumb it in to get circulation.
    Love TFP? Become a
    TFP Supporter!
    30,427
    Re: Anyone successfully shocked a green pool with pump off?
    Anna and zea have summed it up pretty well. If your pool is plaster, you can get the FC in there without harm but filtration is the issue. If it's vinyl, I am not sure I would even attempt to get the chlorine in the pool for concern of bleaching the liner.
    The pool is plaster.
    I've seen some videos showing various guys and gals doing shock process on a green pool. (Could not tell for sure if the pump was on or off)
    Usually they got clear water in a day or two.
    After a day they used a bottle of 'Flock' and that seemed to drop most of the solids to the bottom.
    Have you seen a pool made clear with the pump off, starting from green?
    tips appreciated
    X-PertPool's Avatar
    Exeter, PA
    1,385
    if the water is pea green then shocking it will turn it cloudy blue. It will mostly just stay like that until the water can be filtered. Flocking might help but nothing can really take the place of actually filtering the water.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jun 2008
    Marana, AZ
    347
    I've got an idea for both stirring the water and vacuuming the dead stuff out. You could get a vacuum that operates independantly of the pump entirely; the catfish pool vacuum or pool buster (by water tech) are both fairly good ones. Alternately, if you don't want to spend that much, you could try the little vacuums that hook to the garden hose. These suggestions might not work, but they might be worth a try. Ideas, anyone?
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Dec 2011
    Gold Coast, Australia
    57
    Just to cover all possibilities, if money is not a concern how about reverse osmosis... would that work to clear the dead algae?
    37000 litre, concrete, pebble, Viron P300 pump, Hurlcon VX7T SWCG, Viron CL-400 Cartridge filter, Solar heating, Pandora Smart Robotic cleaner
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by stevodevo
    How would that compare in price to just draining and refilling?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    There isn't much point in shocking with out a working pump. Even if it works, which is somewhat doubtful, the pool will just get algae again in a few days. You also have a major task trying to get the chemicals to mix uniformly without a pump. Chances are you will have too much chlorine in some places, perhaps even enough to cause staining or damage, and too little in other places, likely to let the algae continue growing in those areas.
