Installing an Intelliflo Pump VS along with EasyTouch panel. Pentair double pole 240 GFCI breaker is over about $100, Home Depot sells a Murray Model MP220GFP 20 amp breaker for $65.00. Will the Murray breaker meet the same code?
That's correct. I used cutler's but any qpf works.Ohm_Boy said:Doesn't the EasyTouch use Siemens QPF breakers? Any QPF should work.
Gunnert said:Ordered and received GFCI from Home Depot. At $68 I save about $50 bucks when compared to others...
