Results 1 to 7 of 7
Thread: EasyTouch Pump GFCI Breaker
    Installing an Intelliflo Pump VS along with EasyTouch panel. Pentair double pole 240 GFCI breaker is over about $100, Home Depot sells a Murray Model MP220GFP 20 amp breaker for $65.00. Will the Murray breaker meet the same code?
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    22,553
    Re: EasyTouch Pump GFCI Breaker
    That breaker should work fine. They all have to meet the same requirements.
    Dec 2009
    Central Massachusetts
    2,690
    It should be ok. Just be sure it fits the box. I think they do, just double check.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Doesn't the EasyTouch use Siemens QPF breakers? Any QPF should work.
    Dec 2009
    2,690
    Quote Originally Posted by Ohm_Boy
    That's correct. I used cutler's but any qpf works.
    Ordered and received GFCI from Home Depot. At $68 I save about $50 bucks when compared to others...
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Dec 2009
    2,690
    Quote Originally Posted by Gunnert
