Thread: DIY Kit Items
    Feb 2012
    Maryland
    400
    DIY Kit Items
    Greetings,
    Below is what is coming in my kit, does anyone have a list of other items I would need? I am getting the liner locally and having them install it. Is $6k fair price for 18x36 install pool bottom and liner with liner install?
    Thanks!
    45 Ft x 1-1/2in Standard Swimming Pool Vacuum Hose
    3 Piece Standard Pool Telepole 5 Ft - 15 Ft
    Clearview Pool Vacuum Head
    Standard Leaf Skimmer
    Magnified Pool Thermometer
    18 Inch Aluminum Back Curved Pool Wall Brush
    4-Way Liquid Test Kit
    POLE AND HOSE HOOKS
    KAFKO I/G STEEL POOL KIT
    3 STEP Replacement Stainless Steel Inground Pool Ladder
    Stainless Steel Escutcheon Plate
    Cross Braced Deck Mounted Stair Rail
    SPP 3 Inch Stabilized Chlorine Tablets - 10 Lb
    Hayward Vinyl / Fiberglass Inground Pool Light Niche
    120 Volt Hayward ColorLogic LED Pool Light w/ 50 Ft Cord
    HAYWARD 1 1/2" UNION
    Hayward Super Pump 1 HP 2-Speed Inground Pool Pump -( SP2607X102S , HAYWARD )
    Hayward Pro Series 24 Inch 300# Sand Pool Filter w/ 1.5 Inch Valve -( S244T , Hayward )
    Jandy 1 -1/2 Inch to 2 Inch 3-Port Positive Seal -( 4715 , Jandy )
    Hayward Off-Line Inground Pool Chemical Feeder -( CL220 , Hayward )
    Inground Wall Foam 1/8" X 42" X 125 Ft Roll
    Gladon Spray Adhesive 24 Oz Spray Can
    3/8" BLUE/WHITE (PER FT)
    3/4" CPB STRAIGHT ROPE HOOK
    WALL ANCHOR SET
    3"X5" BLUE/WHITE/BLUE (3/8"ROP
    Super Spring Start-up Kit for Pools to 30K Gallons
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    South Central NJ
    3,192
    Re: DIY Kit Items
    What is the bottom made with?
    The plumbing should only be stubbed with 1-1/2" pipes and the main runs with two inch to the equipment pad. I would use 2"-2/-1/2" Jandy valves, two two inch unions, and a size up one level on the sand filter. I would have preferred to see Pentair or Jandy gear used, especially if it's 2" plumbing as an S244 is 1-1/2" inch and the internal up pipe can crack. I have had problems with Hayward's offerings in the past though I do like the Super Pump for many applications. The use of a CL220 feeder and that you have a low powered two speed may be an issue on low speed. The water's velocity on low speeds and tablet feeders in general is poor performance. Yours fits that mold unfortunately. A salt cell or the use of 3/4HP single speed pump will solve that issue.
    The Pool School section will teach you. Take it and take it seriously.
    Scott
    Owner of - PoolGuyNJ LLC
    Feb 2012
    Maryland
    400
    Re: DIY Kit Items
    Thanks PoolGuy
    The pool bottom will be vermiculite.
    I will look into moving up one level on the filter. And I do plan on going with a salt cell most likely.
    Thanks again!
