Thread: New Pool Owner - Aqua Plus with Total Chemistry
    Feb 2012
    Mesa, AZ
    18
    Hello Everyone, I recently moved into a new home with a pool and spa. I drained the pool, had it cleaned and then installed the Hayward Aqua Plus controller with the Total Chemistry kit and Acid Feed system. I've never owned a pool and really don't understand all this chemistry stuff, but I was hoping to get a somewhat "maintenance free" system. Anyway are there any proven system settings for this set up as far as controlling PH and ORP levels? The other day I was finally able to use my spa after having to replace the heater and I noticed the PH shot up immediately. The acid feed system starting pumping acid and then when I was done with the spa and the water cooled back off the PH was too low and now I'm getting "check system" warnings on the controller. I live in Phoenix, AZ if that has any effect on the settings. Any help would be appreciated. Thanks!!!
    15,000 gallon, Cartridge, In-Ground, Plaster Pool and Spa, Saltwater, Hayward AquaPlus Automated Chlorinator with Total Pool Chemistry Acid Feed System.
    22,551
    Re: New Pool Owner - Aqua Plus with Total Chemistry
    Every pool is different so you won't find any 'set it at this setting and it'll work' recommendations. Also, in and outdoor pool with CYA above about 30 the ORP has a problem. As you've found out, there are no 'maintenance free' systems. They all require some intervention from the user on a regular basis.
    Most people wind up setting the swcg on a percentage and running the acid injection system. You can read a lot about ORP systems here and you'll find very few that have them working well.
    Feb 2012
    Mesa, AZ
    18
    Thanks for the feedback. I've been looking around the forum and other places and have noticed there are a lot of issues with the ORP systems and have thought about disabling it. I'm not sure what swcg stands for, but I'm going to dig a little more into the manual and possibly make the change to percentage as soon as I understand it better.
    22,551
    SWCG - Salt Water Chlorine Generator. Sorry I should have defined it in my post.
    A lot call them swg's but that's not accurate and it's just a pet peeve of mine.
    Oct 2007
    Valrico, FL
    542
    It sounds like the temperature compensation on the pH probe is not work. If you just purchased the equipment new, then it should be in warranty. If that is the case I suggest that you contact Hayward for warranty repair.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Feb 2012
    Mesa, AZ
    18
    Quote Originally Posted by dschlic1
    That makes sense for the pH readings. I didn't know about a temp compensation. I'll give Hayward a call asap. Thanks!!!
