Thread: What Happened?
    What Happened?
    Let's see if you can solve this riddle. Pool pump operating fine in the morning...pressure cleaned patio...problems in the evening.
    Here's what is happening...starting with the pump off and water calm.
    The pump was turned on and water rushed into the skimmer basket like a toilet, because it apparently was very low. A couple minutes later the skimmer basket was back up to the level of the pool which was roughly 1 inch above the bottom of the skimmer basket intake. A couple minutes after that, the skimmer basket emptied again and water began rushing in like a toilet...again. As this kept happening, I noticed that the return jets (x2) seemed to operate with a similar cycle...very little return while the skimmer basket was "refilling" and then good flow while the skimmer basket was "emptying". Also, the pump pressure gauge was lower than normal.
    I took out the filter cartridge, which we bought 3 weeks ago when we moved in, and cleaned it with a hose. It was the first time I've seen it (first pool) so I can't say how dirty it was relative to normal. Cleaning the filter did not solve the problem.
    Do I need to call in an expert or is there something simple to try first?
    Pool Info
    10K gal
    Screened in
    Main drain is closed
    Kreepy Krauly Cruiser attached to skimmer
    2 return jets
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: What Happened?
    Check your skimmer weir. It's probably sticking closed.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: What Happened?
    HIG, welcome to TFP!
    You have what is probably the easiest problem to fix. The weir on your skimmer (the little flap between the pool and the basket) is sticking, and allowing the pump to suck out all the water. Your water is also low; halfway up the skimmer is the normally recommended level. So I'd say fill up the pool to halfway and see if the weir is still sticking.
    Posting anyway, even though John was faster...
    Re: What Happened?
    Bingo...filled the pool a little more and it's working perfectly. Thanks!
    May 2011
    Orange County, CA
    696
    Re: What Happened?
    Hey you guys, that was exactly my first thought as well regarding the skimmer weir and water level. I guess I'm starting to think like a pool guy! Funny thing is that while my current job has nothing to do with pools, I used to "shoot and scoot" pure chlorine gas into pools as a summer job while I was in college. I guess once a pool guy, always a pool guy!
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
