Thread: How soon can I re-test?
    Feb 2012
    Stowe, VT
    59
    Sorry if this is a repeated question as I'm sure it is.
    But how soon can I re-test my water for CH and CYA after I've diluted it with tap water? I've been told 15 minutes for pH and Alk, but this apply?
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: How soon can I re-test?
    I would just make sure it's well mixed and test. A minute, maybe?
    Diluting with tap water is okay for CYA testing, but you need distilled water for the CH dilution.
    Feb 2008
    Denton, TX
    5,061
    On the heels of what Richard320 said, the reason that you need distilled water for CH test dilution is because tap water generally has enough calcium in it already to skew test results. Deionized (distilled) water has no metals to interfere and that is why it is best to use.
