Results 1 to 14 of 14
Thread: Wichita Falls, TX diving pool build
    Just started construction on Friday
    Specs:
    126' waterline
    990 sq ft water surface
    3'6" play depth
    9' diving envelope
    35,000 gal, 3.5-9ft with diving board. Jandy CV580 filter, 2hp 2 speed motor, Pentair Ultra Temp 120 H/C heat pump. Pentair IC60 swg.
    Re: Wichita Falls, TX diving pool build
    Here is a picture of when they started on Friday.
    [attachment=2ubf3fj3]2012-02-28T15-29-53.jpg[/attachmentubf3fj3]
    Then the rebar and plumbing guys showed up on Monday.
    [attachment=1ubf3fj3]2012-02-28T15-30-13.jpg[/attachmentubf3fj3]
    This morning the gunite guys showed up and started spraying
    [attachment=0ubf3fj3]2012-02-28T15-29-17.jpg[/attachmentubf3fj3]
    This is how far they got by lunch. I can't wait to get home from work to checkout the progress.
    Some more pictures at lunch
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Nice! I really like that two-oval design.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    What a great looking shape, looks nice and deep too!
    Thanks for the compliments.
    Here are some pictures from this morning.
    Oct 2009
    3,899
    You must be excited....
    That looks like a pretty steep slope break going into the deep end. Looking back at the layout in your first post I can see it, but I didn't picture it that steep in my head. A random suggestion: I would consider putting a line of tile or something on that edge so people can see where the break is.
    That's a good idea. I'll just need to find a way so it won't look odd in the pool.
    Jun 2011
    Flower Mound, TX
    37
    I like it! Very creative design. Good luck with the build.
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
    Feb 2008
    Denton, TX
    5,061
    Nice looking pool. Good to see someone building a nice, deep diving pool for a change.
    We are officially swimming. They are still working on the spray deck and some rock sitting walls. I'll try and get better some better pictures.
    Oct 2009
    3,899
    That is awesome! No diving board?
    Very nice!
    ____________________________________________________________ ______________________
    In the process of building a Lonestar Fiberglass Pools : Savannah in Caribbean Blue. 13,000 Gallons SWG, 4 therapeutic jets, Pentair 1 HP superflow (348023) pump, 200 Clean & Clear cartridge filter (CCRP-160353), Pentair salt cell IntelliChlor IC40, 3 LED lights, 1 skimmer, cantilever coping with integral light wheat color, and salt-rock pool decking finish.
    Quote Originally Posted by Melt In The Sun
    Yes, we got a diving board. I'll try and run home at lunch and get a better picture.
